willaduncan Posted January 4, 2016 Report Share Posted January 4, 2016 Can you not use profanity its rude were having a conversation about tools here mate.Stop trashing people's threads with your non-sense... Op impact driver, flywheel puller, compression tester, chain breaker/riveter, cable lube tool, torque wrench 1 in inch pounds and 1 in foot pounds, carb sync tool, clutch holder, and cordless impact gun should about cover anything you need to do Sent from my iPhone using Tapatalk 3 Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 4, 2016 Report Share Posted January 4, 2016 A real man would just use the Sledge Hammer do do the cutting. No need to stop for two stroke gas/oil. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 4, 2016 Report Share Posted January 4, 2016 (edited) Get a nice impact driver. Not a big impact gun, just one like the carpenters use. You can get impact rated quater hex to 1/4, 3/8, &. 1/2" socket adaptors. It makes tear downs a breeze. It makes those stubborn phillips come right out like butter. If you got a set of Allen heads that work on a socket, that's another bonus. Most everything else was covered except the 32mm socket for pulling the clutch apart. With an impact, you won't need some janky handle tool to hold it all. Edited January 4, 2016 by trickedcarbine 1 Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted January 5, 2016 Author Report Share Posted January 5, 2016 Top of the line mechanics use top of the line tools. If it ain't top of the line you just ain't top of the line.Agreed to a point, but it's just a screwdriver man... Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted January 5, 2016 Author Report Share Posted January 5, 2016 Thanks guys! Big help. Cannot wait to see this thing on my front door step with Arlo's frame. This is going to be built beautifully. Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted January 5, 2016 Author Report Share Posted January 5, 2016 Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted January 5, 2016 Author Report Share Posted January 5, 2016 ^^^ I have posted it a few times, but the thing is a beaut. Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted January 5, 2016 Author Report Share Posted January 5, 2016 Running center mounted pipes as well. Sent from my SM-G900V using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Yfz350- Posted January 5, 2016 Report Share Posted January 5, 2016 Woah that motor looks nice man, what did that cost to get that an what work has been done to it..I want that motor bro. Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted January 5, 2016 Author Report Share Posted January 5, 2016 Woah that motor looks nice man, what did that cost to get that an what work has been done to it..I want that motor bro.Everything has been done do it, I think. Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
LaegerEliminator Posted January 5, 2016 Report Share Posted January 5, 2016 What does it take to build a leak down kit Sent from my SM-G900V using Tapatalk Do a little searching on here and you will find threads on how to build a proper setup. I can post pics of what I have I you need. 1 Quote Link to comment Share on other sites More sharing options...
LaegerEliminator Posted January 5, 2016 Report Share Posted January 5, 2016 Sent from my SM-G900V using Tapatalk This is definitely sharp looking. Quote Link to comment Share on other sites More sharing options...
Big Mike NY Posted January 5, 2016 Report Share Posted January 5, 2016 What in the world do you need a micrometer for? To check out how much rubber is remaining on your handle bar grips! 0.01 can kill you! Quote Link to comment Share on other sites More sharing options...
Time Machine Posted January 5, 2016 Report Share Posted January 5, 2016 What does it take to build a leak down kit Sent from my SM-G900V using Tapatalk http://bansheehq.com/forums/index.php?/topic/184621-leak-down-test/ Quote Link to comment Share on other sites More sharing options...
lil Doobie420 Posted January 5, 2016 Report Share Posted January 5, 2016 Woah that motor looks nice man, what did that cost to get that an what work has been done to it..I want that motor bro.too fucking bad... Sent from my LGLS740 using Tapatalk Quote Link to comment Share on other sites More sharing options...
