LaegerEliminator Posted November 10, 2015 Report Share Posted November 10, 2015 In your list you have pro mod trans and override. What type of riding will you be doing with this 10mil?X2 Good question Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted November 10, 2015 Report Share Posted November 10, 2015 Serval = Pro Mod I'm guessing he might have been confused on exactly what he needed. Quote Link to comment Share on other sites More sharing options...
vrx46 Posted November 10, 2015 Report Share Posted November 10, 2015 Chop the heal guard mounts on subframe, weird pipe mounts on subframe along with the stuff Tyler said. There is a tab for the tors as well that can go. Now let's see these booty pics! Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted November 10, 2015 Report Share Posted November 10, 2015 http://bansheehq.com/forums/index.php?showtopic=171188&page=1 http://bansheehq.com/forums/index.php?/topic/92210-frame-cutting-should-i-cut-this-off/ Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted November 10, 2015 Report Share Posted November 10, 2015 Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted November 10, 2015 Author Report Share Posted November 10, 2015 Man look at you guys go Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted November 10, 2015 Author Report Share Posted November 10, 2015 Yes, pro mod. I'll will be covering the whole spectrum of riding applications. Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted November 10, 2015 Author Report Share Posted November 10, 2015 CDI mount to the front? I'm not to familiar with this modification. Advantages? Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted November 10, 2015 Report Share Posted November 10, 2015 stock exhaust, airbox, tail light, heel gaurds, if your running cut plastics get rid of those tabs that arent being used, keep most the gussets if its trail bike the weight reduction barely worth the strength you sacrifice Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted November 10, 2015 Report Share Posted November 10, 2015 CDI mount to the front? I'm not to familiar with this modification. Advantages?nothing really. You can run a shorter harness and clean up the bike a bit. 1 Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted November 10, 2015 Report Share Posted November 10, 2015 CDI mount to the front? I'm not to familiar with this modification. Advantages? Just a cleaner install mostly. I don't like wires running to the back of the bike. Plus, my wiring harness is about 10" long. Quote Link to comment Share on other sites More sharing options...
willaduncan Posted November 10, 2015 Report Share Posted November 10, 2015 Just a cleaner install mostly. I don't like wires running to the back of the bike. Plus, my wiring harness is about 10" long. What do you use to remote your CDI to the front? JDS? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted November 10, 2015 Report Share Posted November 10, 2015 What do you use to remote your CDI to the front? JDS? Sent from my iPhone using Tapatalk Yes Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted November 10, 2015 Report Share Posted November 10, 2015 What do you use to remote your CDI to the front? JDS? Sent from my iPhone using Tapatalk I either cut the whole bracket off the rear or I use 6mm coupling nuts to build a mount. Quote Link to comment Share on other sites More sharing options...
willaduncan Posted November 10, 2015 Report Share Posted November 10, 2015 I either cut the whole bracket off the rear or I use 6mm coupling nuts to build a mount.Pictures? I would like another option Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
