4 mil Banshee problem
Hi everyone I'm new to this forum. Anyways i just picked up this beast and it runs great except for it seems to have a slipping clutch in high rpm's. So i got a new driveline performance clutch and its still the same exact problem. As soon as i go full throttle it tops out and doesn't speed up anymore and when i shift its immediately topped out in about every gear. Could any one diagnose this? This is the best way i could describe what its doing. Thanks everyone.
 first completely loosen cable at the handle bar lever. Push the actuator lever to the right with your finger, the arrows should line up.
^^ You can test it first, before tearing it apart ^^
But if it doesn't, loosen the lock nut, turn the phillips screw while holding the lever to the right and stop adjusting when the arrows line up, lock down the nut, double check, done.
