official_style Posted May 7, 2009 Report Posted May 7, 2009 I just put a new OEM yamaha clutch cable on, and i cannot get it adjusted right. to get the correct amount of slack at the perch, i have to have the adjuster screwed like all the way out, so it is falling out of the perch. the clutch case mark and the arrow on the perch line up, what am i doing wrong? the first picture is when the clutch is released, the 2nd is when i push the thing on top of the case to where it stops. Quote
official_style Posted May 7, 2009 Author Report Posted May 7, 2009 an 06 cable should work fine on a 97 right? Quote
SD1026 Posted May 7, 2009 Report Posted May 7, 2009 Ihave the same problem I have like 3 threads in. Quote
official_style Posted May 7, 2009 Author Report Posted May 7, 2009 well it appears the problem is the piece of shit ez pull clutch perch and lever. fucking piece of garbage stretches out, and then you cant take the slack out of the cable. i have only had problems with these stupid cheap ass clutch perches. im ordering a set of asv levers, i have them on my 06 and have none of these problems. ez pull perches are junk, the metal is soo soft and flimsy. Quote
Toomey Banshee Posted May 7, 2009 Report Posted May 7, 2009 Have you tried adjusting the clutch at the clutch? Inside of the clutch cover? You need a phillips head and I think a 10mm or 12mm wrench. That may be the problem as well. Quote
official_style Posted May 7, 2009 Author Report Posted May 7, 2009 i figured this one i didnt have to, since the resistance is starting right where the 2 marks line up. i have done it on other banshees before, but only if the 2 marks are out of alignment. Quote
Toomey Banshee Posted May 7, 2009 Report Posted May 7, 2009 Its been a few seasons since I did that adjustment but if I remember correctly you start with the cable screwed all the way into the perch and adjust the inside from there. Your old cable probably stretched quite a bit knocking that adjustment outta whack. Quote
kwalt21 Posted May 7, 2009 Report Posted May 7, 2009 Dude Toomey you bike in the picture is fucking sweet. Just thought you would like to know :biggrin: Quote
