what jets should i run to get me started
travis6767
I need help getting started with jetting
my elevation is 918 feet above sea level
my mods
Trinity mx port and polish
head shaved
wiseco prolite pistons .030'' over
toomey t-5 pipes
+4 timing
k&n pod filters
stock carbs with tors removal
stock reed cages
Who built the engine for you? Port jobs can be a little tricky to jet depending on who did the work. I would say your probably around a 320-340 main on stock carbs with either 27.5 pilots or 30 pilots. I know its not much help, but maybe someone else will chime in. Your builder would be able to give you the most accurate info though.
