Radiator hose and jets
05shee
Hey everyone, I'm fairly new to the banshee seen and just put on my first real upgrade (pipes). However it seems that no matter how hard i try to position the right pipe it is touching on the radiator hose. Is there anything I can do that would be an easy fix that I'm just over looking. Also i was wondering if you guys could get me close with jets... FMF fatties gold series, K&N filter, removing snorkel, 1500 ft, usually 60-90*. I bought 300 mains and 290s already. Thanks.
On my PT mids the rad house almost always touches the pipes. I tried to rig it up different ways with zip ties and such, and I got it decent. Just make sure the hose isnt starting to melt and it should be ok.
As for jetting are you running a full air box, just without the snorkel?
If so you should be at a 260 main
25 pilots with about 1.5 turns out on the air screw
Needle with clip on the middle
Those 290s and 300s are going to be too big if you still have a lid on that air box.
alright thanks for the help ill pick up the tape tomorrow
i forgot to add that i am also running 40:1 mix also and yes its full airbox just k&n with snorkel off
How much do your banshees smoke with a rev at idle... mine very lightly smokes with 25 pilots and 2 turns out then if i crack it to half and let off it shoots a fairly good cloud out of the pipes pretty white/light grey in color then if i get it to just barely touching powerband theres no smoke at all.. could this be rich needle and lean mains?
