bellracing2 Posted August 13, 2008 Report Share Posted August 13, 2008 do any other quad rear shocks fit the banshee rear end ? I already have the eibach 8.9 rate spring and still not heavy enough ! stock lenght swinger for 300 lb rider . any ideas ? (besides loose weight ! ) :biggrin: Quote Link to comment Share on other sites More sharing options...
Onesickcrewcab Posted August 13, 2008 Report Share Posted August 13, 2008 do any other quad rear shocks fit the banshee rear end ? I already have the eibach 8.9 rate spring and still not heavy enough ! stock lenght swinger for 300 lb rider . any ideas ? (besides loose weight ! ) :biggrin: That shock not work out for you? I am the same weight you are. Not sure what other bike applications fit the banshee. You could always go Elka like I did, but thats only because I went to a +8 swinger. Or you can always send the stock shock out and have it re valved for your weight. Quote Link to comment Share on other sites More sharing options...
bellracing2 Posted August 13, 2008 Author Report Share Posted August 13, 2008 That shock not work out for you? I am the same weight you are. Not sure what other bike applications fit the banshee. You could always go Elka like I did, but thats only because I went to a +8 swinger. Or you can always send the stock shock out and have it re valved for your weight. Its much better than what I had , but still not strong enough . comp dampening is maxed and still too spongey . Quote Link to comment Share on other sites More sharing options...
