crazyj789 Posted May 20, 2010 Report Share Posted May 20, 2010 1) What type of aftermarket exhaust do you have? (Paul Turner Mids with fatboy 2 silencers) 2) What type of airfilter do you have? K&N 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all (Stock airbox with proflow adaptor and K&N powerlid) 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) (600-800 ft. above) 5) What size pilot jets are you using? (27.5) 6) What size main jets are you using? (300) 7) What temperature is your Banshee jetted for? (60-90 degress F) 8) Do you have a port job? (stock port) 9) What kind of carbs? (stock TORS removed) 10) What size carbs? (stock TORS removed) Needle clip 2nd postion from top due to VF2 reeds Quote Link to comment Share on other sites More sharing options...
98yfz350 Posted May 27, 2010 Report Share Posted May 27, 2010 1) What type of aftermarket exhaust do you have? stock 2) What type of airfilter do you have? Pro Flo 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all ... YES 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 4200ft and 8200ft 5) What size pilot jets are you using? idk i guess stock.. the guys i bought it from ran it at red sands new mexico and mentioned that he put new jetts and they we 38 s 6) What size main jets are you using? 38 7) What temperature is your Banshee jetted for? 90s 8) Do you have a port job? no 9) What kind of carbs? stock 10) What size carbs? stock Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted June 8, 2010 Report Share Posted June 8, 2010 1) What type of aftermarket exhaust do you have? FMF Fattys 2) What type of airfilter do you have? K&N 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all STOCK air box no lid 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 1500 ft. 5) What size pilot jets are you using? 27.5 6) What size main jets are you using? 290 7) What temperature is your Banshee jetted for? 60-90 degress F 8) Do you have a port job? stock port 9) What kind of carbs? stock TORS removed 10) What size carbs? stock TORS removed Also run VF2, +4 timing, and needle is in the middle position. Quote Link to comment Share on other sites More sharing options...
sahara Posted June 11, 2010 Report Share Posted June 11, 2010 (edited) 1) What type of aftermarket exhaust do you have? CPI inframe 2) What type of airfilter do you have? pod K&N 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 4500' 5) What size pilot jets are you using? ?? 6) What size main jets are you using? 380 7) What temperature is your Banshee jetted for? 70 8) Do you have a port job? 196 Exhaust and 130 transfer 9) What kind of carbs? Mikuni 10) What size carbs? 30mm Edited June 11, 2010 by sahara Quote Link to comment Share on other sites More sharing options...
dumbasswithshee Posted June 18, 2010 Report Share Posted June 18, 2010 1) What type of aftermarket exhaust do you have?T5 2) What type of airfilter do you have?K&N pods 3) d) no airbox at all 4) What is your elevation? Sea Level 5) What size pilot jets are you using?27.5 6) What size main jets are you using?340 7) What temperature is your Banshee jetted for?80ish 8) Do you have a port job?MX? 9) What kind of carbs?Stock 10) What size carbs?Bored to 28mm Quote Link to comment Share on other sites More sharing options...
Hallgren31 Posted July 2, 2010 Report Share Posted July 2, 2010 1) What type of aftermarket exhaust do you have? Toomey T-5 2) What type of airfilter do you have? K&N 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all No Airbox 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 2750 Feet 5) What size pilot jets are you using? 6) What size main jets are you using? 155 7) What temperature is your Banshee jetted for? 20c/65f 8) Do you have a port job? NO 9) What kind of carbs? Kehinen 10) What size carbs? 35mm Quote Link to comment Share on other sites More sharing options...
banshee67 Posted July 8, 2010 Report Share Posted July 8, 2010 Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have? toomey t6 2) What type of airfilter do you have? stock filter 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all modified airbox 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 3000 ish 5) What size pilot jets are you using? 27.5 6) What size main jets are you using? 280 7) What temperature is your Banshee jetted for? mild 8) Do you have a port job? stock 9) What kind of carbs? mikuni 10) What size carbs? 26 Thanks! Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted July 8, 2010 Report Share Posted July 8, 2010 Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have? toomey t6 2) What type of airfilter do you have? stock filter 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all modified airbox 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 3000 ish 5) What size pilot jets are you using? 27.5 6) What size main jets are you using? 280 7) What temperature is your Banshee jetted for? mild 8) Do you have a port job? stock 9) What kind of carbs? mikuni 10) What size carbs? 26 Thanks! dude, you stole my name.. that is my username on my chainsaw forum.. ive also seen a banshee67 on raptorforum in the past i better change mine before i get tied in with the likes of you guys Quote Link to comment Share on other sites More sharing options...
twoody Posted July 12, 2010 Report Share Posted July 12, 2010 1) What type of aftermarket exhaust do you have? procircuit w/ 304 silencers 2) What type of airfilter do you have? k&n pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all: d 4) What is your elevation? 600-800 5) What size pilot jets are you using? 48 6) What size main jets are you using? 152 7) What temperature is your Banshee jetted for? 80's or so 8) Do you have a port job? yes, clean up port 9) What kind of carbs? keihin pwk 10) What size carbs? 28 -also i'm 1 turn out on air screw and running w/ +4 timing 1 Quote Link to comment Share on other sites More sharing options...
rockenshee Posted July 25, 2010 Report Share Posted July 25, 2010 1) What type of aftermarket exhaust do you have? fatty pc2 2) What type of airfilter do you have? k&n 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all? A 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 1460 5) What size pilot jets are you using? 27.5 1.5 turns out 6) What size main jets are you using? 260 7) What temperature is your Banshee jetted for? 15C 8) Do you have a port job? no 9) What kind of carbs? stock 10) What size carbs? 26mm Quote Link to comment Share on other sites More sharing options...
ritchieb Posted August 5, 2010 Report Share Posted August 5, 2010 1) What type of aftermarket exhaust do you have? DMC 916 2) What type of airfilter do you have? Pro design foam filter 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all. Stock/ power core lid 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 0 - 316 metres 5) What size pilot jets are you using? 42 6) What size main jets are you using? 155 7) What temperature is your Banshee jetted for? 25 c 8) Do you have a port job? yes 9) What kind of carbs? PWK 10) What size carbs? 28 Quote Link to comment Share on other sites More sharing options...
muggzy Posted August 21, 2010 Report Share Posted August 21, 2010 1) What type of aftermarket exhaust do you have? Pro Circuit Platinums 2) What type of airfilter do you have? K&N Stock rplacement 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all. 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 900ft 5) What size pilot jets are you using? 27.5 6) What size main jets are you using? 280 summer/300 winter; Needle clip on pos. 4 (1 richer than Center) 7) What temperature is your Banshee jetted for? 60 - 100 summer/30 - 60 winter 8) Do you have a port job? Yes, don't know any details 9) What kind of carbs? Stock Mikuni VM26SS 10) What size carbs? 26mm Quote Link to comment Share on other sites More sharing options...
Love Boat Posted August 23, 2010 Report Share Posted August 23, 2010 Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have? T5 2) What type of airfilter do you have? UNI w/ ProFlow 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all? B 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 2700 5) What size pilot jets are you using? Stock 6) What size main jets are you using? 280 7) What temperature is your Banshee jetted for? 75-95 8) Do you have a port job? No 9) What kind of carbs? Stock 10) What size carbs? Stock 11) 50:1 Premix Thanks! Quote Link to comment Share on other sites More sharing options...
alex_219 Posted August 25, 2010 Report Share Posted August 25, 2010 1) What type of aftermarket exhaust do you have? T5s 2) What type of airfilter do you have? K&N 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all B 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 600-700 5) What size pilot jets are you using?stock 6) What size main jets are you using? 270 7) What temperature is your Banshee jetted for? 70-90 8) Do you have a port job? no 9) What kind of carbs?stock 10) What size carbs?stock Quote Link to comment Share on other sites More sharing options...
tom582 Posted September 21, 2010 Report Share Posted September 21, 2010 1) What type of aftermarket exhaust do you have? fmf gold 2) What type of airfilter do you have? k&n 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all vented... 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 920ft 5) What size pilot jets are you using? 27.5 6) What size main jets are you using? 280 7) What temperature is your Banshee jetted for? 50-80 8) Do you have a port job? no 9) What kind of carbs? stock 10) What size carbs? stock Quote Link to comment Share on other sites More sharing options...
