What jets are you using? Fill out this form...
1) What type of aftermarket exhaust do you have? CPI big bore inframes
2) What type of airfilter do you have? Stock K&N replacement
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all?
Stock airbox, no Lid
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 1500 ft above sea level
5) What size pilot jets are you using? 27.5
6) What size main jets are you using? 420's!!!!!!
7) What temperature is your Banshee jetted for? 60-70 degrees F
8) Do you have a port job? Will have a port job by friday and have to rejett it with a new top end
9) What kind of carbs? Stock
10) What size carbs? Stock
1) What type of aftermarket exhaust do you have? fmf gold series
2) What type of airfilter do you have? k&n
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all C
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 900ft
5) What size pilot jets are you using? Stock
6) What size main jets are you using? 340
7) What temperature is your Banshee jetted for? 70+
8) Do you have a port job? Not sure. just had new top end put in
9) What kind of carbs? stock 2001 banshee
10) What size carbs? stock
Thanks!
  • 4 months later...
1) Toomey T5
2) K/N
3) stock box modded lid
4) idk less than 400 above sea level?
5) 27.5
6) 290-310 still waiting for the weather to tell me
7) working on it but for now its cold out and 300 works fine
8) no port job :(
9) stock carbs
10) 26mm
11) 1.5 out
12) middle position?? :confused:
13) stock timing
i see a few ported and piped bikes with stock jets :shootself:
  • 2 weeks later...
1) What type of aftermarket exhaust do you have? T5'S
2) What type of airfilter do you have? K&N
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all NO LID
4) What is your elevation? (If you don't know, go here: http://www.topozone.com )1200
5) What size pilot jets are you using? 52
6) What size main jets are you using? 158
8) Do you have a port job? NOT YET
9) What kind of carbs? PWK
10) What size carbs? 28MM
11) Stock bore and stroke 12) 40to1 yamalube
1) What type of aftermarket exhaust do you have? Pro Circuit Platnium
2) What type of airfilter do you have? Twin Air Pods/Outwears
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all. D read answer 2
4) What is your elevation? 1000-3500ft
5) What size pilot jets are you using? 48
6) What size main jets are you using? 160's, may try 162's
7) What temperature is your Banshee jetted for? 20-100F
8) Do you have a port job? Passion Trail Port
9) What kind of carbs? OKO's
10) What size carbs? 30MM
11) Air screws? .75 out
12) Needle and position? JJH on the middle clip
13) Timing? +5
1) What type of aftermarket exhaust do you have? CPI Inframes
2) What type of airfilter do you have? Pods w/outerwears
5) What size pilot jets are you using? 50
7) What temperature is your Banshee jetted for? 50-75
8) Do you have a port job? HJR Dune Port
9) What kind of carbs? Keihin
10) What size carbs? 28's
11) Air screws? 1.5 turns out
12) Needle and position? N68a on middle clip
13) Timing? +4
4) What is your elevation? 5000
5) What size pilot jets are you using? stock
6) What size main jets are you using? 310
7) What temperature is your Banshee jetted for? 70-90
8) Do you have a port job? WILDCARD Aggressive Dune
12) Needle and position? middle clip
13) Timing? +4
1) What type of aftermarket exhaust do you have? Toomey T5
2) What type of airfilter do you have? K/N
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all -----> Stock with lid no snorkel 10 holes
4) What is your elevation? 827 ft
5) What size pilot jets are you using? 35
6) What size main jets are you using? 330
7) What temperature is your Banshee jetted for? 60-80
8) Do you have a port job? mild
9) What kind of carbs? Mikuni
11) Air screws? 1.5 out
13) What kind of reeds? V-force 3
14) What size bore? 64.50 mm
Updating since from my last post a long time ago
1) What type of aftermarket exhaust do you have? T-5
2) What type of airfilter do you have? 6" CLAMP ONS
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all b---NO AIRBOX
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) ~580 FT
6) What size main jets are you using? 155
8) Do you have a port job? DUNE PORT
10) What size carbs? 33MM
11) Air screws? 1.25 out
CPI inframe
k and n pods
no box
3500 ft
48s i think
155
70+
hjr dune ported 4mill stroker
pwk
35mms
  • 2 weeks later...
1) What type of aftermarket exhaust do you have? FMF Fatty
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all -----> Stock air box with no lid
4) What is your elevation?Sea level
5) What size pilot jets are you using? 32.5
6) What size main jets are you using? 300
7) What temperature is your Banshee jetted for? 55-75
8) Do you have a port job? no
12) Needle and position? 4th clip down
13) What kind of reeds? Stock
14) What size bore? 64mm (stock)
  • 4 weeks later...
1) What type of aftermarket exhaust do you have? --------shearer small bore in frames
2) What type of airfilter do you have?----------- K/N pods
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all--------no airbox
4) What is your elevation? --------------sealevel
5) What size pilot jets are you using? ------------27.5
6) What size main jets are you using? -----------300
7) What temperature is your Banshee jetted for?-------- 80 +
8) Do you have a port job? ----------cleanup
9) What kind of carbs? --------mikuni
10) What size carbs? ---------- stock 26mm
11) Air screws?--------- 1.5 out
12) Needle and position?------- stock / middle
13) Timing? -------+4
Please copy and paste this along with your answers in your reply, thanks.
1) What type of aftermarket exhaust do you have? T5 MID-HI REVS
2) What type of airfilter do you have? UNI 2-STAGE ANGLED PODS
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all PODS
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 0 TO 1800FT
5) What size pilot jets are you using? 48 & DEK NEEDLE ON THIRD CLIP
6) What size main jets are you using? 185
7) What temperature is your Banshee jetted for? 0 to 60
8) Do you have a port job? VITO'S 10 PORT ATHENAS WITH POWER PISTONS
9) What kind of carbs? A.S.K KIEHINS
10) What size carbs? 35MM
Thanks!
  • 2 weeks later...
1. T-5
2. 2 k&n pods
3. see number 2
4 sea level
5. 32.5
6. 310
7. i dont know
8. ya mild
9. stock
10. stock 26mm
11. 1.5
12. toomie/ 5th down. wana trade for stock needles. eneyone
13. +10
