lowbuckracing Posted May 22, 2009 Report Share Posted May 22, 2009 4mill,stock cylinder,dune port,35mm pwk-162 rd mains...sea level middle clip cek needle t5 toomeys Quote Link to comment Share on other sites More sharing options...
RollinRhino Posted May 23, 2009 Report Share Posted May 23, 2009 (edited) Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have? Pro Circuit 2) What type of airfilter do you have? K&N with outerwear 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all Stock Box with drilled out lid 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 880 ft 5) What size pilot jets are you using? 25 6) What size main jets are you using? 280 or 300 (depends on air temp) 7) What temperature is your Banshee jetted for? 70 degrees 8) Do you have a port job?No 9) What kind of carbs? Mikuni 10) What size carbs? 28mm Thanks! Edited May 23, 2009 by RollinRhino Quote Link to comment Share on other sites More sharing options...
bansheeqc Posted May 26, 2009 Report Share Posted May 26, 2009 My stock trail bike 1) What type of aftermarket exhaust do you have? Pro circuit 2) What type of airfilter do you have? Durablue Foam 3) Stock airbox with lid. snorkel removed 4) What is your elevation? 482 ft above sea level 5) What size pilot jets are you using? 25 (stock) 6) What size main jets are you using? 240 7) What temperature is your Banshee jetted for? 10-30 degree C 8) Do you have a port job? NO 9) What kind of carbs? Stock 10) What size carbs? 26mm (stock) Quote Link to comment Share on other sites More sharing options...
2strokesmoker Posted June 1, 2009 Report Share Posted June 1, 2009 Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have? Toomey T-5 2) What type of airfilter do you have? K&N pro design adapter plate 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all a 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 755 above sea level 5) What size pilot jets are you using? 25's now but need to go up to a 30 6) What size main jets are you using? 310 7) What temperature is your Banshee jetted for? 70 8) Do you have a port job? not yet 9) What kind of carbs? stock 10) What size carbs? stock 26's? Quote Link to comment Share on other sites More sharing options...
Whitbread Posted June 2, 2009 Report Share Posted June 2, 2009 1) What type of aftermarket exhaust do you have? Paul turner high rev's 2) What type of airfilter do you have? K&n pod 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all D) no airbox 4) What is your elevation? ~1000ft 5) What size pilot jets are you using? 35, air screw 3 turns out 6) What size main jets are you using? 155 with an EEJ needle, 4th clip 7) What temperature is your Banshee jetted for? 75F 8) Do you have a port job? Drag port 9) What kind of carbs? Keihin 10) What size carbs? Single 34PJ Quote Link to comment Share on other sites More sharing options...
swhitey917 Posted June 2, 2009 Report Share Posted June 2, 2009 1) What type of aftermarket exhaust do you have? ---Paul Turner MIds with Fatboy 2 silencers 2) What type of airfilter do you have? ---UNi foam filter 3) Stock airbox (lid and snorkel removed) 4) What is your elevation? --- 545 ft above sea level 5) What size pilot jets are you using? ---25 stock 6) What size main jets are you using? --- 200 7) What temperature is your Banshee jetted for? --- above 65 degrees F 8) Do you have a port job? ---No (I wish) 9) What kind of carbs? --- Stock 10) What size carbs? ---Stock 26mm Quote Link to comment Share on other sites More sharing options...
evro Posted June 22, 2009 Report Share Posted June 22, 2009 1) full DG exhaust 2) K&N filters 3) no airbox/pods 4) 1600+ feet 5) 27.5 pilots 6) 310 mains 7) needle clip in the middle 7) 10-30 C 50-90 F 8) no port 9) stock carbs 10) 26's 11) Air screws 1.5 turns out Quote Link to comment Share on other sites More sharing options...
someone82 Posted July 7, 2009 Report Share Posted July 7, 2009 1) What type of aftermarket exhaust do you have? Toomey T-5 2) What type of airfilter do you have? K&n pod 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all D) no airbox 4) What is your elevation? sealevel to 3500ft 5) What size pilot jets are you using? 42, air screw 2 turns out 6) What size main jets are you using? 190 7) What temperature is your Banshee jetted for? 75ish 8) Do you have a port job? MX port 9) What kind of carbs? Keihin 10) What size carbs? Single Pwk 35 Air striker on a Graydon intake 11) Needle? DGN 2nd clip down from top 12) Timing? +4 degress Quote Link to comment Share on other sites More sharing options...
Sandfrk33 Posted July 9, 2009 Report Share Posted July 9, 2009 1) What type of aftermarket exhaust do you have? Toomey t-5's 2) What type of airfilter do you have? Uni 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all. D 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 2400 5) What size pilot jets are you using? 27.5 6) What size main jets are you using? 300 7) What temperature is your Banshee jetted for? 90's 8) Do you have a port job? yes 9) What kind of carbs? mikunis 10) What size carbs? Stockers bored to 28 mil Quote Link to comment Share on other sites More sharing options...
Banshee Roost Posted July 25, 2009 Report Share Posted July 25, 2009 1) What type of aftermarket exhaust do you have? Pro Circuit Platinums,304 silencers. 2) What type of airfilter do you have? Twin Air power flow foam kit. 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all? B Stock airbox no lid at all. 4) What is your elevation? 1100ft. 5) What size pilot jets are you using? Mikuni 27.5 6) What size main jets are you using? Mikuni 320 7) What temperature is your Banshee jetted for? 85-100 deg. 8) Do you have a port job? No. 9) What kind of carbs? Stock Mikuni. 10) What size carbs? Stock 26mm Mikuni. Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted September 28, 2009 Report Share Posted September 28, 2009 1) What type of aftermarket exhaust do you have? ROCKETS 2) What type of airfilter do you have? K/N 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all.... Air box for dirt, pods for sand. 4) What is your elevation? 1500 and up to 10K ft +! 5) What size pilot jets are you using? 45 6) What size main jets are you using? 155 7) What temperature is your Banshee jetted for? 60-90F 15-34C 8) Do you have a port job? F.A.S.T. Dune Port 9) What kind of carbs? Oko's 10) What size carbs? 30MM 11) Air screws? 1.5 out 12) Needle and position? N68A's on the second to top clip 13) Timing? +5.5 14) Ball size and positin to ride it? Big, hairy and riding in the lower portion of the sack!!! Quote Link to comment Share on other sites More sharing options...
RippinShee Posted October 6, 2009 Report Share Posted October 6, 2009 1) What type of aftermarket exhaust do you have? CPI Inframes 2) What type of airfilter do you have? K/N 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all.... Airbox with EHS Open Lid 4) What is your elevation? 800' 5) What size pilot jets are you using? 45 6) What size main jets are you using? 155 7) What temperature is your Banshee jetted for? 50-90 F 8) Do you have a port job? Full Drag Port 9) What kind of carbs? Keihin PJ'S 10) What size carbs? 34MM 11) Air screws? 1.5 out 12) Needle and position? CEL on Middle Clip 13) Timing? +5.5 Quote Link to comment Share on other sites More sharing options...
banshee-mike Posted October 6, 2009 Report Share Posted October 6, 2009 1) What type of aftermarket exhaust do you have?fmf fatty and pc2s 2) What type of airfilter do you have?k&n pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all?no air box 4) What is your elevation? (If you don't know, go here: http://www.topozone.com )sea level 5) What size pilot jets are you using?30 6) What size main jets are you using?320 7) What temperature is your Banshee jetted for?80-90 deg 8) Do you have a port job?no 9) What kind of carbs?stock with tors removed 10) What size carbs?26 mm Thanks! 1 Quote Link to comment Share on other sites More sharing options...
joker03banshee Posted October 15, 2009 Report Share Posted October 15, 2009 1) What type of aftermarket exhaust do you have?bills pipes 2) What type of airfilter do you have?k&n 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all?C 4) What is your elevation? (If you don't know, go here: http://www.topozone.com )1500-2000 5) What size pilot jets are you using?30 6) What size main jets are you using?250 7) What temperature is your Banshee jetted for?n/s 8) Do you have a port job?no 9) What kind of carbs?stock with tors removed 10) What size carbs?26 mm Thanks! Quote Link to comment Share on other sites More sharing options...
T_Shee Posted October 15, 2009 Report Share Posted October 15, 2009 1) What type of aftermarket exhaust do you have? dmc 916 2) What type of airfilter do you have? K/N pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all.... no airbox 4) What is your elevation? 1000 ft 5) What size pilot jets are you using? 50(need to go smaller) 6) What size main jets are you using? 150 7) What temperature is your Banshee jetted for? 60-80 f 8) Do you have a port job? cleanup 9) What kind of carbs? keihin 10) What size carbs? 28mm 11) Air screws? 1.5 out 12) Needle and position? cgl middle 13) Timing? +4 Quote Link to comment Share on other sites More sharing options...
