bombedbanshee06 Posted April 29, 2009 Report Share Posted April 29, 2009 1) What type of aftermarket exhaust do you have? Tommey tr6 2) What type of airfilter do you have? K&N 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all stock with lid on 4) What is your elevation? sea level 5) What size pilot jets are you using? 30 6) What size main jets are you using? 330 7) What temperature is your Banshee jetted for? australian weather 8) Do you have a port job? no 9) What kind of carbs? STD 10) What size carbs STD Quote Link to comment Share on other sites More sharing options...
gst_r Posted April 29, 2009 Report Share Posted April 29, 2009 1) What type of aftermarket exhaust do you have? Cut T3 Pipes 2) What type of airfilter do you have? K&N Pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all No box 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) At Sea level 5) What size pilot jets are you using? 38 6) What size main jets are you using? 140 7) What temperature is your Banshee jetted for? 50-90 8) Do you have a port job? Drag/Full Port 9) What kind of carbs? Keihin PJ 10) What size carbs? 34mm Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted May 1, 2009 Report Share Posted May 1, 2009 (edited) 1) What type of aftermarket exhaust do you have? CPI inframes 2) What type of airfilter do you have? K&N pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all no air box 4) What is your elevation? sea level 5) What size pilot jets are you using? 48 6) What size main jets are you using? 155 7) What temperature is your Banshee jetted for? high 80's for right now 8) Do you have a port job? Flotek port job for my riding style/mods/pipes 9) What kind of carbs? OKO 10) What size carbs? 30mm 11)e-clip 2nd from top Edited May 1, 2009 by RagunCajun Quote Link to comment Share on other sites More sharing options...
ban06shee Posted May 6, 2009 Report Share Posted May 6, 2009 1) What type of aftermarket exhaust do you have? Toomey T6's 2) What type of airfilter do you have? K&N 5"pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all? D)no airbox at all 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 2,389ft 5) What size pilot jets are you using? have no idea 6) What size main jets are you using? 320 7) What temperature is your Banshee jetted for? hell, tucson, AZ 8) Do you have a port job? no 9) What kind of carbs? stock 10) What size carbs? stock Quote Link to comment Share on other sites More sharing options...
gbody Posted May 10, 2009 Report Share Posted May 10, 2009 (edited) Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have? pro circuit platinum 2) What type of airfilter do you have? K&N 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all ............NO air box 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 16.4 ft 5) What size pilot jets are you using? stock 6) What size main jets are you using? stock 7) What temperature is your Banshee jetted for? 70-95 * 8) Do you have a port job? yes / bored .060 over shaved .020 off stock head 9) What kind of carbs? stock 10) What size carbs? stock Thanks! Edited May 10, 2009 by gbody Quote Link to comment Share on other sites More sharing options...
lincster Posted May 14, 2009 Report Share Posted May 14, 2009 1) What type of aftermarket exhaust do you have? Toomey T5s 2) What type of airfilter do you have? Toomey 2:1 intake 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all No airbox at all 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 800' 5) What size pilot jets are you using? 30 6) What size main jets are you using? 370 7) What temperature is your Banshee jetted for? 35-75F 8) Do you have a port job? No 9) What kind of carbs? Stock 10) What size carbs? Stock Quote Link to comment Share on other sites More sharing options...
strutha Posted May 15, 2009 Report Share Posted May 15, 2009 1) What type of aftermarket exhaust do you have? FMF fattys 2) What type of airfilter do you have? std 3) std air box no snorkel 4) What is your elevation? sea level 5) What size pilot jets are you using? 30 6) What size main jets are you using? 340 1.4 air jet 7) What temperature is your Banshee jetted for? 10-25c 8) Do you have a port job? custom 1uA - RZ 31K barrels 9) What kind of carbs? Stock 10) What size carbs? Stock Quote Link to comment Share on other sites More sharing options...
DallasGDub Posted May 15, 2009 Report Share Posted May 15, 2009 1) What type of aftermarket exhaust do you have? FMF Fats w/PC2's 2) What type of airfilter do you have? K&N w/Proflow 3) Box? Stock air box, no lid. 4) What is your elevation? Just above sea level. North TX. 5) What size pilot jets are you using? 50 6) What size main jets are you using? 155 7) What temperature is your Banshee jetted for? 70-85 8) Do you have a port job? HJR Full Dune port 9) What kind of carbs? Keihin PWK 10) What size carbs? 28mm Quote Link to comment Share on other sites More sharing options...
blayzwon Posted May 15, 2009 Report Share Posted May 15, 2009 Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have? FMF FATTYS w/ PCII's 2) What type of airfilter do you have? UNI foam 3) vented airbox with lid. snorkel removed 4) What is your elevation? 760 ft above sea level 5) What size pilot jets are you using? ?? 6) What size main jets are you using?280 7) What temperature is your Banshee jetted for? under 68 8) Do you have a port job? dont think so... havent been that far in yet 9) What kind of carbs? mikuni VM series 10) What size carbs? 28mm i believe i am pretty sure they are stock with TORS I NEED HELP!!!! Thanks! Quote Link to comment Share on other sites More sharing options...
dave88 Posted May 16, 2009 Report Share Posted May 16, 2009 (edited) 1) What type of aftermarket exhaust do you have? t-5 2) What type of airfilter do you have? k&n 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all no air box 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) sealevel 5) What size pilot jets are you using? 50 6) What size main jets are you usin 162 7) What temperature is your Banshee jetted for 60-75 8) Do you have a port job? yes dune port 9) What kind of carbs? oko 10) What size carbs? oko Edited May 16, 2009 by dave88 Quote Link to comment Share on other sites More sharing options...
Sammy Posted May 16, 2009 Report Share Posted May 16, 2009 1) What type of aftermarket exhaust do you have? PTR mids w/ Fatboy2 silencers 2) What type of air filter do you have? k&n 3) Are you a)running a stock air box with lid stock air box with NO lid c) Stock air box with vents d) no air box at all no air box 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 600 ft 5) What size pilot jets are you using? 27.5 6) What size main jets are you using? 320 7) What temperature is your Banshee jetted for? 60-75 degrees F 8) Do you have a port job? Stock port 9) What kind of carbs? Mikuni 10) What size carbs? Stock Quote Link to comment Share on other sites More sharing options...
TwistedSheeRida Posted May 16, 2009 Report Share Posted May 16, 2009 (edited) 1) What type of aftermarket exhaust do you have? FMF SST 2) What type of airfilter do you have? K&N with proflow 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all B Stock airbox without lid 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 278ft 5) What size pilot jets are you using? 25 i believe 6) What size main jets are you using? 260 7) What temperature is your Banshee jetted for? Runs best around 70 degrees 8) Do you have a port job? No 9) What kind of carbs? Stock Mikuni 10) What size carbs? 26mm BAM Edited May 16, 2009 by TwistedSheeRida Quote Link to comment Share on other sites More sharing options...
06specialedition Posted May 16, 2009 Report Share Posted May 16, 2009 1) What type of aftermarket exhaust do you have? CPI Inframes 2) What type of airfilter do you have? K&N's Pods w/ Outerwears 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all D) no airbox at all 4) What is your elevation? (If you don't know, go here: <a href="http://www.topozone.com" target="_blank">http://www.topozone.com</a> ) ~5000 ft. (St. Anthony, ID and Little Sahara, UT) 5) What size pilot jets are you using? 25's (stock) 6) What size main jets are you using? 310's 7) What temperature is your Banshee jetted for? 80 F 95 F 8) Do you have a port job? Wildcard Racing Aggressive Dune 9) What kind of carbs? Mikuni's (stock) 10) What size carbs? 26 mm Quote Link to comment Share on other sites More sharing options...
Hubcap Posted May 22, 2009 Report Share Posted May 22, 2009 1) What type of aftermarket exhaust do you have? CT Racing MX Pipes 2) What type of airfilter do you have? K&N Pods w/outerwears 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all No Air Box 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 2844' 5) What size pilot jets are you using? 50 6) What size main jets are you using? 150 Needle CEL clip 4th from top 7) What temperature is your Banshee jetted for? 70-100 8) Do you have a port job? HJR Dune/Hill Shooting 9) What kind of carbs Keihn 10) What size carbs? 34PJ's Quote Link to comment Share on other sites More sharing options...
LIM_Whiteboy4life Posted May 22, 2009 Report Share Posted May 22, 2009 (edited) 1) What type of aftermarket exhaust do you have? Toomey T5 2) What type of airfilter do you have? K&N Pods w/outerwears 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) Sea level 5) What size pilot jets are you using? ?? 50 i guess, never looked. 6) What size main jets are you using? 160 7) What temperature is your Banshee jetted for? 70-90F 8) Do you have a port job? HJR Dune/play 9) What kind of carbs OKO/Keihn(knock off) 10) What size carbs? 30mm Seems about perfect with 2 turns on airscrew, middle clip. Edited May 22, 2009 by LIM_Whiteboy4life 2 Quote Link to comment Share on other sites More sharing options...
