1) What type of aftermarket exhaust do you have?
Toomey T6s
2) What type of airfilter do you have?K&N
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all
A
4) What is your elevation? (If you don't know, go here: http://www.topozone.com )
530
5) What size pilot jets are you using?
27.5
6) What size main jets are you using?
300
7) What temperature is your Banshee jetted for?
runs good now(23 F) but prob 70-90ish
8) Do you have a port job?
no
9) What kind of carbs?
stock
10) What size carbs?
stcok
  • 2 weeks later...
1) What type of aftermarket exhaust do you have? PTR Mids, Fat Boy II silencers
2) What type of airfilter do you have? Pro-design Foam
3) Stock Airbox with lid, no snorkle
4) What is your elevation? 500 MSL
5) What size pilot jets are you using? 27.5
6) What size main jets are you using? 320
7) What temperature is your Banshee jetted for? 30F
8) Do you have a port job? stock
9) What kind of carbs? stock
10) What size carbs? stock
11) Reeds? Boysen stock cages
12) Air screws? at 2 turns
13) Needle? Stock, 5th notch (very bottom notch)
Please copy and paste this along with your answers in your reply, thanks.
1) What type of aftermarket exhaust do you have? fmf fattys with silencers
2) What type of airfilter do you have? uni with prefilter
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all D
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) sea level
5) What size pilot jets are you using? maybe stock
6) What size main jets are you using? 340 down to 320
7) What temperature is your Banshee jetted for? dont know
8) Do you have a port job? yes
10) What size carbs? 26mm
Thanks!
Edited by mo-powah
Toomey T-5s
K&N w/outerware
Stock box with no lid, and a proflow adapter
Sea Level
48
158
70-80*
MX/Trail Port
Sudco Kleihn PWKs
28's
13) Crank?
Stock Trued and Welded
14) Head/domes?
Stock
15) Reeds?
Ported stock cages w/ Boyesen 2 Stage Reeds
16) Pistons/bore?
MH racing 65mm pistons
17) Premix ratio/oil/fuel?
40:1 Blenzall Ultra 91 oct
18) Timing?
+4
Edited by someone82
1) What type of aftermarket exhaust do you have? CPI inframes
2) What type of airfilter do you have? K&N
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all B
4) What is your elevation? 800
6) What size main jets are you using? 310
7) What temperature is your Banshee jetted for? 50-75
8) Do you have a port job? Not yet
9) What kind of carbs? Stock Mikuni
10) What size carbs? 28mm
11) What reeds? V force 3
12) What setting is your clip on? 2nd down from the top, was in the middle before the reeds.
shearer inframes (SB)
pods
2000
wide range
yes
lectrons
38
11)crank?
vito's 4mil
with the right gearing this makes an awesome top end wheeler! excellent post!!
Edited by studroes
  • 4 weeks later...
1) What type of aftermarket exhaust do you have? DMC 916
2) What type of airfilter do you have? k&n POD
K&N POD
sea level
stock (25)
280
60-80
no
stock
10)stock needle clip
11) 1 turn out on air fuel screws
Edited by blaster2006
TOOMEY's T5's
3x5 K&N's w/ Outerwears
D) no airbox at all
~5000 ft. (St. Anthony, ID and Little Sahara, UT)
25's (stock)
290's
70 F -85 F
Not Yet
Mikuni's (stock)
26 mm
Edited by BumpaD_Z28
motofast 2in1
bstock box no lid and proflow intake
450ish
40
145
not yet
kihen
26mm
  • 3 weeks later...
FMF fattys w/silencers
foam
bstock box vented lid and proflow intake
1100ft
30
340
phoenix
not yet
stock
26mm
11) stock reeds w/ aftermarket petals
1) What type of aftermarket exhaust do you have? toomey t-5
2) What type of airfilter do you have? kn proflow in airebox with no lid
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) sealevel to 1300 ish
5) What size pilot jets are you using? stock
6) What size main jets are you using? 300 or 310 dont remember
7) What temperature is your Banshee jetted for? all year runs beautiful
8) Do you have a port job? nope
Thanks!
fmf gold
uni
i ride anywhere from 800 to 1200 feet
27.5
320
60-80 deg f
no
stock
stock
