1) What type of aftermarket exhaust do you have? - FMF Fatty Gold + Power Core II silencers
2) What type of airfilter do you have? - UNI 6" pods with outerwears
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all
- No Airbox
4) What is your elevation? - 600ft ASL
5) What size pilot jets are you using? - 25 (thinking about going to 27.5 or 30)
6) What size main jets are you using? - 310
7) What temperature is your Banshee jetted for? - 40-80*F
8) Do you have a port job? - yes.. not sure what though
9) What kind of carbs? - Mikuni Stockers minus TORS
10) What size carbs? - stock
11) Shaved head? Not yet.
(these are before the current work.. it was boggy on the bottom and I am reboring/shaving the head)
Toomey T5s
K&N Pods
D, no airbox at all
4) What is your elevation? (If you don't know, go here: http://www.topozone.com )
Sea Level
Stock (Might want to bump up...slight bog off idle)
350 Mains - No Airbox
70-105* (I'd be scared above that)
Not yet
Stock, w/o TORS
Stockers
  • Like 1
1) What type of aftermarket exhaust do you have? T6
2) What type of airfilter do you have?K&N pods
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all. none!
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 800 ft.
5) What size pilot jets are you using? Stock
6) What size main jets are you using? 330
7) What temperature is your Banshee jetted for? 70-100
8) Do you have a port job? yes agressive dune port.. herr jugs racing
9) What kind of carbs? stock
10) What size carbs? stock
Edited by '04limited
1) What type of aftermarket exhaust do you have? FMF gold FULL
2) What type of airfilter do you have? K&N
3) Are you (B) stock airbox with NO lid )
4) What is your elevation? 1,240
5) What size pilot jets are you using?45
6) What size main jets are you using?270
7) What temperature is your Banshee jetted for? lean DRAG RACEING
8) Do you have a port job?YES
9) What kind of carbs?STOCK MILLED OUT
10) What size carbs?28
1) Shearer SB Out-of-Frames
2) 8" Clamp-ons
3) No Air Box
4) 1,200 ft.
5) 52-55 pilots
6) 172-175 mains
7) 70-90*F
8) 4mm Cubs Drag Ported
9) 39 PWKs
10) 39 PWKs
  • 1 month later...
Great thread!!
1) What type of aftermarket exhaust do you have? Toomey T5'S
2) What type of airfilter do you have? K&N Pods
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all No air box
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) Sea level to 500ft
5) What size pilot jets are you using? 27.5
7) What temperature is your Banshee jetted for? 50 to 90
8) Do you have a port job? Redline Racing
10) What size carbs? 26 Mill
Great idea guys keep this up.
:thumbsup:
1) What type of aftermarket exhaust do you have? Trinity Stage IV
2) What type of airfilter do you have? 8in k&n Pods w/ outerwears
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all. No Box
4) What is your elevation? 1,200asl
5) What size pilot jets are you using? 50
6) What size main jets are you using? 158
7) Air screw? 1.5 turns out
8) needles? CEL Middle clip
9) What temperature is your Banshee jetted for? 70-100
10) Do you have a port job? dune port
11) What kind of carbs? Kehin PJ's
12) What size carbs? 34PJ's
13) Crank? 4mill 5mill longrods
14) Head/domes? Pro design 18cc cut for long rod
15) Reeds? V2
16) Pistons/bore? 795 series 64.50
17) Premix ratio/oil/fuel? 40:1, Castor 927,110 octain
18) Timing? +6
Damn Vortech,
Now I gotta upgrade my Banshee.
Gotta add a hot ass chick to the top of it !! LOL
CPI Inframes
K&N pods w/outerwears
D
1100ft
50
162
40/50f
Passion dune/drag
PWK Airstrykers
35mm
11) Bore ? Stroke? Compression?
64.5mm +4mil 175psi
12) Timing plate ?
+6 deg.
Please copy and paste this along with your answers in your reply, thanks.
1) What type of aftermarket exhaust do you have? trinity stage 4
2) What type of airfilter do you have? k&n
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all b
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 500ft asl
7) What temperature is your Banshee jetted for? new build not sure
9) What kind of carbs? oko(Keihin)
10) What size carbs? 30mm
Thanks!
  • 2 weeks later...
1) What type of aftermarket exhaust do you have? FMF Gnarly/Powercore II Silencers
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all? Stock box w/lid
4) What is your elevation? 1100Ft
6) What size main jets are you using? 280
7) What temperature is your Banshee jetted for? 60 or above
8) Do you have a port job? No porting
9) What kind of carbs? Stock Mikuni
10) What size carbs? Stock
