MILD BUILD BANSHEE
1) What type of aftermarket exhaust do you have?
toomy t5s
2) What type of airfilter do you have?
k&n pods
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all
no air box
4) What is your elevation? (If you don't know, go here: http://www.topozone.com )
5k foot dunes
5) What size pilot jets are you using?
27
6) What size main jets are you using?
310
7) What temperature is your Banshee jetted for?
80+
8 ) What type of riding
this is set up for aggressive dune riding.
9 ) bore/psi on cylinders
64.5mm cylinders with a cool head and 19cc domes (165psi at 500foot)
10) Do you have a port job?
mild home brew, just to help everything flow no angles or roof/Floors changed
11) What kind of carbs?
stock
12) What size carbs?
26mm
13) Any other motor mods?
vf4 reeds
  • 2 months later...
On 9/8/2020 at 10:04 PM, Jon2021 said:
Hello all. Have a old build jd jug with 596cc 10 mill. Yes 596ccs
has  39 pkw s, previously added. It’s a panini  build with unmarked duncan pipes and cascade silencers.. Any suggestions for the best tune? Timing? Jet sizes? Previouse owner had stock 39 mm jets and timing was retarded to six deg adv..It kickes backed at starting and lacks top end.  I’m thinking adv back to 10 deg and run 60 Idle and 164 main jets. It’s supposed to be a 120-130 hp build.  Suggestions please.. Thxs
  • 2 months later...
  • 4 months later...
- None / still OEM
- pro design Foam air filter
3) Are you a)running a stock airbox with lid, stock airbox with NO lid c) Stock airbox with vents d) no airbox at all
- stock airbox with lid without snorkel
- between Sea Level and 100 Meters
- OEM Size
- 230 Mikuni
- 0° to 10° Celsius
8) Do you have a port job?
- nope
9) What kind of carbs?
- the crappy OEM Mikuni Carbs
10) What size carbs?
- 26mm
Edited by Qliphoth
  • 9 months later...
1) stock pipes with fatboy silencers
2- stock foam twin air
3- stock air box no holes
4) no clue above sea level
5) 22.5
6) 210
7) no idea
8 - nope stock cylinders prox piston
9) stock of a rdlc 31k 28mm carbs
10- 28mm
  • 2 years later...
1) どのようなタイプのアフターマーケット排気装置をお持ちですか?
FMF GOLD SERIES FATTY FMFsilencer turbine Core
2) どのようなタイプのエアフィルターをお持ちですか?
normal
3) a) 蓋付きの純正エアボックスを使用していますか、B)蓋なしの純正エアボックスを使用していますか、c) 通気口付きの純正エアボックスを使用していますか、d) エアボックスを全く使用していませんか
Remains genuine
4) 標高はどのくらいですか? (わからない場合は、こちらをご覧ください: http://www.topozone.com )
2〜90メートル
5) どのサイズのパイロットジェットを使用していますか?
25
6) どのサイズのメインジェットを使用していますか?
240
7) Banshee の噴射温度はどのくらいですか?
Don't know
😎 港湾の仕事はありますか?
Don't know
9) どんな炭水化物ですか?
normal
10) 炭水化物のサイズは?
normal
  • 3 weeks later...
Shearer inframe
Pods
No airbox
1310
45
148
37 degrees
😎 Do you have a port job?
Duneport
Keihin pwk
34mm
Shearer inframe
Pods
No airbox
1310
45
148
37 degrees
Duneport
Keihin pwk
34mm
Stroker? How many cc?
