What jets are you using? Fill out this form...
On 8/12/2008 at 3:37 PM, vortechblown306 said:
Please copy and paste this along with your answers in your reply, thanks.
1) What type of aftermarket exhaust do you have?
2) What type of airfilter do you have?
K&N style
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all
B
4) What is your elevation? (If you don't know, go here: http://www.topozone.com )
Glamis
5) What size pilot jets are you using?
27.5
6) What size main jets are you using?
270
7) What temperature is your Banshee jetted for?
20-60
8) Do you have a port job?
clean up
9) What kind of carbs?
stock, tors eliminated
10) What size carbs?
stock
Thanks!
  • 3 months later...
FMF fatty pipes and silencers
K&N style
Airbox with cut up lid
Seal level to 1000 feet
48
162
35 to 60
Trail ported
Keihin pwk
28mm
  • 2 weeks later...
  • 5 weeks later...
Tommey t3
stock filter
335
stock pilot jet
stock main jet
70 degrees
no
stock
stock
Thanks!
  • 2 months later...
FMF fattys, powercore 1 silencers
K&N
Stock airbox, lid opened up and vents, no snorkel
Sea level
30
370
50
Trail ported
Stock mikuni with dynojet needle with 6 grooves, clip at 2 groove from the top.
26mm
11) Miscellaneous
Coolhead, 22cc domes, +3 timing advance.
Thanks!
  • 3 months later...
fmf gnarly power core 2
pro desiegn
stock airbod with billit adapter and lid no snorkel
5500
25
220
80-100
no
stock
Thanks!
  • Thanks 1
  • 2 months later...
On 8/30/2017 at 11:29 AM, ginger said:
^^ no one is going to help you if you cant provide correct information.
you pilot is not 240.  your main might be.
your pilot might be 25
click on the link provided for your elevation, we arent going to do it for you.
Sorry
Fmf gold series power core 2
K&n cone
 K&n power filter lid
Mainly 300ft but some times 20-1100ft
25
240
70-90 ma summer weather
No thinking about it tho
Stock
10) What size carbs
stock
  • 1 year later...
Toomey T5
K&N pods
No airbox
945ft above sea level
25
310, could have gone leaner and made slightly more hp but played it safe with slightly rich
10 degrees to 90 degrees
😎 Do you have a port job?
No
Stock
Stock
  • 2 months later...
Thanks!
Cpi in frame pipes
k&n filters
no air box
1200 feet
47 pilot
190 mains
85 to 90f
full drag port
pwk
34mm custom machined Velocity stacksVelocity stacks
  • 2 weeks later...
Hi there new to the forum, im looking for advise! I don’t know what jets to pit on my banshee. The mods are t6 pipes, vforce reeds, pc coolhead, after market air filter in stock air cleaner box with vented lid. I cleaned the carbs and found that it currently has 270 mains and 25 piolets, the needle is set 3rd notch and the elevation is 2030 in las vegas temp ranges from 70-115f. I was able to get the quad stable at 1/2 turn out on the air screw and 1.5 on the idle stock tors. The bike has a stable idle but i wonder if the jets are correct for the mods? I have not done plug chops yet dont want to risk running it lean and causing unwanted damage to the bike. Can i get some guidance please.
That sounds spot on for the main for your temp and elevation, V-force reeds like a bigger pilot and your air screws only being out a 1/2 turn confirms that. Bump up to a 27.5
  • 1 month later...
—-SB shearer inframes!
—K&N style!
—-No airbox!
 —-600!
—N/A!
—-N/A!
—-N/A!
—-LP Triple exhaust port!
—-35 pwk!
 —35
VF4 Reeds
Thanks!
Edited by 101questions
  • 3 months later...
Hello all. Have a old build jd jug with 596cc 10 mill. Yes 596ccs
has  39 pkw s, previously added. It’s a panini  build with unmarked duncan pipes and cascade silencers.. Any suggestions for the best tune? Timing? Jet sizes? Previouse owner had stock 39 mm jets and timing was retarded to six deg adv..It kickes backed at starting and lacks top end.  I’m thinking adv back to 10 deg and run 60 Idle and 164 main jets. It’s supposed to be a 120-130 hp build.  Suggestions please.. Thxs
  • 2 months later...
Toomey T5 pipes
K&N
Air box/No lid
Sea level
300
Not sure
No
Mikuni
28
Thanks!
  • 1 month later...
1) What type of aftermarket exhaust do you have?T5
K&N pods
No air box
500-100
55
155
70-80
No but bored to 66.50
Keihin
35mm
im having trouble Trying to jet my bike don’t know what size pilot and main to run thanks
