bansheesickness Posted August 19, 2008 Report Posted August 19, 2008 1) What type of aftermarket exhaust do you have?paul turner mids 2) What type of airfilter do you have?k&n pods 3) no airbox at all 4) What is your elevation? sea level 5) What size pilot jets are you using?50 6) What size main jets are you using?200 7) What temperature is your Banshee jetted for?60-75 8) Do you have a port job?hjr dune/hillsot port 9) What kind of carbs? pwk 10) What size carbs?35 mm 11)dek needle 3rd clip down 2nd shee 1) What type of aftermarket exhaust do you have?paul turner mids 2) What type of airfilter do you have?k&n pods 3) no airbox at all 4) What is your elevation? sea level 5) What size pilot jets are you using?50 6) What size main jets are you using?205 7) What temperature is your Banshee jetted for?60-75 8) Do you have a port job?tirnitys 400cc cub, w/cleanup port 9) What kind of carbs?pwk singel 10) What size carbs?38mm 11)eej needel 4th clip down 1 Quote
mdhc500 Posted August 19, 2008 Report Posted August 19, 2008 (edited) 1) FMF Fatty's w/PowerCore Silencers 2) K&N 3) Stock box with lid on, snorkle off 4) 1350 ft MSL 5) Stock Pilots 5a) Needle on 3rd clip 6) 270 7) 69.5 degrees F. SAT 8) Do you have a port job? NO 9) What kind of carbs? Mikuni 10) What size carbs? Stock Thanks! Edited August 19, 2008 by mdhc500 Quote
shee4speed Posted August 20, 2008 Report Posted August 20, 2008 1) What type of aftermarket exhaust do you have?Shearer inframes (smallbore) 2) What type of airfilter do you have?K&N Pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all D,Not at all 4) What is your elevation? (If you don't know, go here: http://www.topozone.com )sea level 5) What size pilot jets are you using? stock 6) What size main jets are you using?360 7) What temperature is your Banshee jetted for?any 8) Do you have a port job?agressive dune port fro HJR 9) What kind of carbs?Mikuni 10) What size carbs?stock -- But this is all going to be old news when I get new carbs very soonly. Thanks! No, Thank You 1 Quote
dragbanshee Posted August 20, 2008 Report Posted August 20, 2008 1) What type of aftermarket exhaust do you have? T5s 2) What type of airfilter do you have? K&N 2into1 pod 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all d. 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 800asl 5) What size pilot jets are you using? 50 6) What size main jets are you using? 158 7) What temperature is your Banshee jetted for? 60-100 8) Do you have a port job? no 9) What kind of carbs? oko's/kehins 10) What size carbs? 30mm Quote
Banshee Roost Posted August 23, 2008 Report Posted August 23, 2008 1) What type of aftermarket exhaust do you have? FMF Fatty Power Core II's 2) What type of airfilter do you have? Twin Air Power Flow Foam Kit. 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all d. B Stock Airbox no lid. 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 1,100 feet. 5) What size pilot jets are you using? Stock 3rd clip. 6) What size main jets are you using? 320. 7) What temperature is your Banshee jetted for? 60-100 8) Do you have a port job? no 9) What kind of carbs? Stock Mikuni's 10) What size carbs? 26mm Quote
bbcmudtruck Posted August 25, 2008 Report Posted August 25, 2008 1) What type of aftermarket exhaust do you have? T5s 2)What type of airfilter do you have? K&N 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all B 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 1000' 5) What size pilot jets are you using? 27.5 6) What size main jets are you using? 340s 7) What temperature is your Banshee jetted for? 85 8) Do you have a port job? HerrJugsRacing Dune/Hillshooter 9) What kind of carbs? Stock (Till next week) 10) What size carbs? Big ass 26s' Good thread :thumbsup: Sticky Sticky Sticky Quote
vortechblown306 Posted August 29, 2008 Author Report Posted August 29, 2008 (edited) ty ttt Good thread :thumbsup: Sticky Sticky Sticky Edited August 29, 2008 by vortechblown306 Quote
magz Posted August 29, 2008 Report Posted August 29, 2008 (edited) 1) What type of aftermarket exhaust do you have? T6's 2)What type of airfilter do you have? K&N Pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all d 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 700 5) What size pilot jets are you using? 25 6) What size main jets are you using? 320's 7) What temperature is your Banshee jetted for? 85 8) Do you have a port job? stock - But currently at passions racing getting a agressive dune port 9) What kind of carbs? Stock 10) What size carbs? 26s - Next on the list to upgrade 11) Timing plate Ricky Stator at 4+ 12) does it run good at these settings? Runs awsome, no bogs, strong throughout. good in dunes and awsome on trails Edited August 29, 2008 by magz Quote
SCEADU Posted August 30, 2008 Report Posted August 30, 2008 1) What type of aftermarket exhaust do you have? Fatty's with pwer core II's 2)What type of airfilter do you have? K&N 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all No lid with a outer ware 4) What is your elevation? 1200 5) What size pilot jets are you using? 30's 6) What size main jets are you using? 330's witht the needle on the 4th richest setting 7) What temperature is your Banshee jetted for? "HOT LANTA" 8) Do you have a port job? Trail port 9) What kind of carbs? Stock] 10) What size carbs? 26 11) +4 timing 12) Minor bog out of the hole but HOLD THE HELL ON in the mid and top!! Quote
gumby6t9 Posted August 31, 2008 Report Posted August 31, 2008 1) What type of aftermarket exhaust do you have? T6's 2) What type of airfilter do you have? K&N Pods w/ outerwears 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all NONE! 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 850ft 5) What size pilot jets are you using? 50 (will probably up them one size today to cure a bottom end bog / flat power) 6) What size main jets are you using? 155 7) What temperature is your Banshee jetted for? 80's 8) Do you have a port job? Yes - Flotek 9) What kind of carbs? PWK 10) What size carbs? 28mm Quote
robert.b.west Posted September 4, 2008 Report Posted September 4, 2008 1) What type of aftermarket exhaust do you have? T-6 2) What type of airfilter do you have? UNI W/ OUTERWARE 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all B 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 700 FT 5) What size pilot jets are you using? STOCK 6) What size main jets are you using? 380 A LITTLE RICH PROBABLY SHOULD BE A 360-370 7) What temperature is your Banshee jetted for? ~80F 8) Do you have a port job? YES DUNE PORT 9) What kind of carbs? STOCK (SOON TO BE KEIHIN PWK 33MM) 10) What size carbs? 26MM Quote
fastbanshee8 Posted September 4, 2008 Report Posted September 4, 2008 1) What type of aftermarket exhaust do you have? CPI inframe 2) What type of airfilter do you have? K&N Pods w/outerwears 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all No airbox 4) What is your elevation? 1,580 ft 5) What size pilot jets are you using? 40 6) What size main jets are you using? 290 7) What temperature is your Banshee jetted for? 90+ 8) Do you have a port job? Yes 9) What kind of carbs? Mikuni 10) What size carbs? 34mm Quote
fastrthnu Posted September 4, 2008 Report Posted September 4, 2008 1) What type of aftermarket exhaust do you have? Rockets 2) What type of airfilter do you have? K&N 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all stock box no lid cut in 1/2 diag. 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 32` 5) What size pilot jets are you using? 27.5 6) What size main jets are you using? 370 7) What temperature is your Banshee jetted for? 80-90 degrees 8) Do you have a port job? passion racing 12 port 9) What kind of carbs? mikuni flatslide 10) What size carbs? 28mm Quote
downNdirty Posted September 4, 2008 Report Posted September 4, 2008 1) What type of aftermarket exhaust do you have? Fmf Fatty 2) What type of airfilter do you have? Pro design foam with outerwear 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all box with lid no snorkel and sometimes no lid 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) sea level to 1,500 feet 5) What size pilot jets are you using? Stock 6) What size main jets are you using? With lid no snorkel 260 no lid 280 7) What temperature is your Banshee jetted for? 70+ 8) Do you have a port job? nope 9) What kind of carbs? stockers 10) What size carbs? Quote
