prosser9981 Posted October 12, 2015 Report Share Posted October 12, 2015 (edited) 1) What type of aftermarket exhaust do you have? Toomey T6 2) What type of airfilter do you have? k&n 3) Are you a)running a stock airbox with k&n power lid 4) What is your elevation? 252' 5) What size pilot jets are you using?27.5 6) What size main jets are you using?320 7) What temperature is your Banshee jetted for? 70-80 8) Do you have a port job? Yes 9) What kind of carbs? Stock 10) What size carbs? Stock Edited October 12, 2015 by prosser9981 Quote Link to comment Share on other sites More sharing options...
Buster91dg Posted December 8, 2015 Report Share Posted December 8, 2015 1) What type of aftermarket exhaust do you have? Fmf fattys with silencers 2) What type of airfilter do you have? K&n air filter no lid 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all B 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 500 5) What size pilot jets are you using?30 6) What size main jets are you using? 270 7) What temperature is your Banshee jetted for? Not sure 8) Do you have a port job? No 9) What kind of carbs? Mikuni 10) What size carbs? 26 Bored .50 over Quote Link to comment Share on other sites More sharing options...
02Banshee88 Posted February 23, 2016 Report Share Posted February 23, 2016 (edited) 1) What type of aftermarket exhaust do you have? FMF Gold Series Fatty w/ Powercore Silencer 2) What type of airfilter do you have? K&N YA-3502 High Performance Air Filter 3) Currently a stock airbox with NO lid 4) What is your elevation? 600ft abs 5) What size pilot jets are you using? 30, but may be changed to 27.5 this week 6) What size main jets are you using? 290 mains 7) What temperature is your Banshee jetted for? 60-70 8) Do you have a port job? No 9) What kind of carbs? OEM 10) What size carbs? Stock 26mm Thanks! Edited February 23, 2016 by 02Banshee88 1 Quote Link to comment Share on other sites More sharing options...
600racer Posted March 15, 2016 Report Share Posted March 15, 2016 Updated 1) What type of aftermarket exhaust do you have? T5s 2) What type of airfilter do you have? K&N pods 3) no air box 4) What is your elevation? 0-1000 5) What size pilot jets are you using? 48 air screw .5 turns 6) What size main jets are you using? 158 7) What temperature is your Banshee jetted for? 70- 100f 8) Do you have a port job? 4 mil dune port 9) What kind of carbs? Keihn pj with vf4 10) What size carbs? 34mm Quote Link to comment Share on other sites More sharing options...
Prescottguy89 Posted November 28, 2016 Report Share Posted November 28, 2016 1) What type of aftermarket exhaust do you have? Tommey t5 2) What type of airfilter do you have? uni no outter wear 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all No box 4) What is your elevation? 5000 ft 5) What size pilot jets are you using? 40 6) What size main jets are you using? 310 7) What temperature is your Banshee jetted for? 75 8) Do you have a port job? Full drag port 9) What kind of carbs? stock 10) What size carbs? Stock Quote Link to comment Share on other sites More sharing options...
Fast2stroke Posted November 29, 2016 Report Share Posted November 29, 2016 1) What type of aftermarket exhaust do you have? (CPI Inframes) 2) What type of airfilter do you have?(Uni pods w/outerwears) 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) (5000 ft.) 5) What size pilot jets are you using? (25....stock) 6) What size main jets are you using? (310's) 7) What temperature is your Banshee jetted for? (80 deg F.) 8) Do you have a port job? (Aggressive dune port 196 deg ex- 125.5 deg trans) 9) What kind of carbs? (mikuni) 10) What size carbs? (VM 26...stock) 11) Premix ratio? (40:1) How do you like the CPI in frames bro are they worth it. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Snortin.norton Posted April 4, 2017 Report Share Posted April 4, 2017 1) What type of aftermarket exhaust do you have? DMC 916 2) What type of airfilter do you have? Pods 6" 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all no air box 4) What is your elevation? (If you don't know, go here: http://www.topozone.com) 300m above sea level 5) What size pilot jets are you using? 27.5 6) What size main jets are you using? 280 7) What temperature is your Banshee jetted for? ... Stock ? 8) Do you have a port job? No 9) What kind of carbs? Stock 10) What size carbs? Stock Starting is my issue. It's like I have to warm it up by kicking it over before it starts. Once it starts it runs awesome, can't figure it out 1 Quote Link to comment Share on other sites More sharing options...
STRIBZ Posted June 14, 2017 Report Share Posted June 14, 2017 1) What type of aftermarket exhaust do you have? FMF FATTYS 2) What type of airfilter do you have? K&N PODS 3) no air box 4) What is your elevation? SEA LEVEL 5) What size pilot jets are you using? 27.5 6) What size main jets are you using? 350 7) What temperature is your Banshee jetted for? 25-35 CELCIUS 8) Do you have a port job? 421 AS CAST DRIVELINE LOW PORT 9) What kind of carbs? STOCK W/ VF4 10) What size carbs? 26MM 1 Quote Link to comment Share on other sites More sharing options...
greg_banshee Posted June 20, 2017 Report Share Posted June 20, 2017 1) Shearer SB IF2) UNI two stage pods 3) No air box4) 250-1000'5) 30 Pilots (1.5 turns out on AS)6) 360 Mains (5DP39 needles on 5th clip from blunt end & 175 p8 needle jets)7) 15-25 C8) +4mm Stock cylinder Dune/Play port with 23cc Stroker domes from Noss. 9) Mikuni TM28's with VForce-3 reeds10) 28mm flat slides Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
dirtdigginjoe Posted June 23, 2017 Report Share Posted June 23, 2017 1) What type of aftermarket exhaust do you have? Toomey T5 2) What type of airfilter do you have? Uni Foam Pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all No airbox- Uni foam pods 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 1500-2200ft mostly. Every once in a while, I bring it down to sea level. 5) What size pilot jets are you using? 52- Only way these POS carbs would idle. 6) What size main jets are you using? 150 7) What temperature is your Banshee jetted for? 50+ 8) Do you have a port job? Yes- Woods/MX port 4mil stroke 9) What kind of carbs? Keihin PJs. Judge me all you want. 10) What size carbs? 34mm Quote Link to comment Share on other sites More sharing options...
rinaldobailey Posted July 1, 2017 Report Share Posted July 1, 2017 1) What type of aftermarket exhaust do you have? Bills Pipes2) What type of airfilter do you have? Uni pods3) No airbox4) What is your elevation? 250 to 700 ft asl5) What size pilot jets are you using? 456) What size main jets are you using? 1427) What temperature is your Banshee jetted for? 70f to 90f8) Do you have a port job? No9) What kind of carbs? Keihin PWK10) What size carbs? 28mm'sSent from my SM-G920W8 using Tapatalk Quote Link to comment Share on other sites More sharing options...
rinaldobailey Posted July 1, 2017 Report Share Posted July 1, 2017 1) What type of aftermarket exhaust do you have? Bills Pipes2) What type of airfilter do you have? Uni pods3) No airbox4) What is your elevation? 250 to 700 ft asl5) What size pilot jets are you using? 456) What size main jets are you using? 1427) What temperature is your Banshee jetted for? 70f to 90f88) Do you have a port job? No9) What kind of carbs? Keihin PWK10) What size carbs? 28mm's11) V Force 4 reeds 12) stock stroke crankSent from my SM-G920W8 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Banshee508 Posted August 30, 2017 Report Share Posted August 30, 2017 Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have? Fmf gold series fattys with powercore 2 2) What type of airfilter do you have? K&n cone filter with stock foam filter over it 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all running a stock air box with a k&n power lid 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) Idk live in Worcester ma area 5) What size pilot jets are you using? 240 6) What size main jets are you using? .25 think 7) What temperature is your Banshee jetted for? Hot 70-90s 8) Do you have a port job? Not sure 9) What kind of carbs? Believe stock 10) What size carbs? Welcom Quote Link to comment Share on other sites More sharing options...
ginger Posted August 30, 2017 Report Share Posted August 30, 2017 ^^ no one is going to help you if you cant provide correct information. you pilot is not 240. your main might be. your pilot might be 25 click on the link provided for your elevation, we arent going to do it for you. Quote Link to comment Share on other sites More sharing options...
Canadianshee Posted August 30, 2017 Report Share Posted August 30, 2017 1) What type of aftermarket exhaust do you have? FMF Fatty with power core 2 silencers 2) What type of airfilter do you have? Prodesign mount and filter 3) Are you a)running a stock airbox no lid 4) What is your elevation? 650 ft / 198 m5) What size pilot jets are you using? 27.56) What size main jets are you using? 3307) What temperature is your Banshee jetted for? 25 to 35 degrees C 8) Do you have a port job? HJR MX ported9) What kind of carbs? OEM Stock tors delete10) What size carbs? Stock 26mmSent from my LG-H831 using Tapatalk Quote Link to comment Share on other sites More sharing options...
