What jets are you using? Fill out this form...
UPDATE
1) What type of aftermarket exhaust do you have? FMF fattys w/ turbinecore2
2) What type of air filter do you have? STOCK
3) What type of airbox do you have? STOCK,no snorkle
4) Whats your elevation? ~5000ft
5) What size pilot jets are you using? 30s
6) What size mains are you using? 230s
7) What temperature is your banshee jetted for? Idk, for nice days.
8) Do you have a port job? Not that I am aware of, but do have VFORCE4 reeds and bored 0.020" over.
9) What kind of carbs? STOCK, tors delete
10) What size carbs? STOCK
  • 2 weeks later...
1) What type of aftermarket exhaust do you have? DMC Alien
2) What type of airfilter do you have?   Pro Design Foam filter with intake flange
3) Are you a)running a stock airbox with lid without snorkel
4) What is your elevation? between 500 and 650 FT
5) What size pilot jets are you using?    30.0
6) What size main jets are you using?    280
7) What temperature is your Banshee jetted for?  50-60°F
8) Do you have a port job? no
9) What kind of carbs? RD 350 4L0 Carbs, Mikuni
10) What size carbs? 26MM
Edited by Robert80
1) What type of aftermarket exhaust do you have? Pro circuit
3) Are you running a)Stock box with lid on,holes drilled in top
4) What is your elevation? 160-190ft(Adelaide-Australia)
5) What size pilot jets are you using? 25.0
6) What size main jets are you using?    270
7) What temperature is your Banshee jetted for?22-28* C
9) What kind of carbs? Stock
I just purchased this bike and it was really smokey on initial start up.but cleared up after warming up.i have only ridden up the street and back then parked it.
So i have drained fuel,(which was old)cleaned out carbies,airbox,filter,Changed plugs,decarboned exhausts and is now ready to fire up but just wanted to check specs first.
It also has a boost bottle,pilot air screw wound out 2 turns from hard seated,5n7 needle on #3 setting.
thanx
  • 1 month later...
Very new to this. 88 banshee, 0.030 over, Toomey T5 exhaust. I'm at about 900ft elevation. I bought the quad with 2 left carbs so I'm replacing them. trying to figure out what size carbs/jets I should run. Mostly just trail riding this season. I'm thinking 28mm carbs and clueless on jetting. I have no air box yet the quad is completely stripped down to the frame and I'm trying to put it back together the right way. HAAAALP!
2) What type of airfilter do you have?   Pro Design foam filter with intake flange
4) What is your elevation? 1033FT
1) What type of aftermarket exhaust do you have? Fmf fatty gold series
2) What type of airfilter do you have? K&N
3) Are you a)running a stock airbox with lid cool.gif stock airbox with NO lid c) Stock airbox with vents d) no airbox at all. Stock box with snorkel removed
4) What is your elevation? 1200
5) What size pilot jets are you using? 27.5
6) What size main jets are you using? 300
7) What temperature is your Banshee jetted for? 60-80
8) Do you have a port job? Stock
10) What size carbs? Stock
  • 3 weeks later...
2) What type of airfilter do you have? Pro Design w/intake flange
3) Running a stock airbox with NO lid
4) What is your elevation? 3000ft
6) What size main jets are you using? 290
7) What temperature is your Banshee jetted for? 15-25*C
10) What size carbs? 26mm
1) What type of aftermarket exhaust do you have? Pro Circuit 304s
2) What type of airfilter do you have? K&N pods
3) no air box
4) What is your elevation? 3500
7) What temperature is your Banshee jetted for? 70- 100C
1) What type of aftermarket exhaust do you have? T5s
3) no air box
4) What is your elevation? 0-1000
5) What size pilot jets are you using? 52-55 air screw .5 turns
6) What size main jets are you using? 158
7) What temperature is your Banshee jetted for? 70- 100f
8) Do you have a port job? 4 mil dune port
9) What kind of carbs? Keihn
10) What size carbs? 34mm
  • 3 weeks later...
3) Are you a)running a stock airbox with lid cool.gif stock airbox with NO lid c) Stock airbox with vents d) no airbox at all CUSTOM
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) round 150ft above sea level
5) What size pilot jets are you using? 48
6) What size main jets are you using? 145
8) Do you have a port job? 421 cheetah P.V
9) What kind of carbs? Keihen
10) What size carbs? Pj 34mm
Edited by Deuczwild
  • 1 month later...
  • 4 weeks later...
1) What type of aftermarket exhaust do you have? sb shearer
2) What type of airfilter do you have? pod's 8"
3) Are you a)running a stock airbox with lid cool.gif stock airbox with NO lid c) Stock airbox with vents d) no airbox at all D
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) nearly sea level
6) What size main jets are you using? 162
8) Do you have a port job? full drag
10) What size carbs? 35mm
348 stock bore stock stroke
Cpi inframes modified fmf power core 2 silencers
Aggressive race ported cylinders w match ported cases
Ported stock reed cages w/ boyesen carbon reeds
Lighten flywheel
Stock ignition advanced +5
28mm keihin pwk on 110 fuel
K+n pods w/ outerwear
158 main
45 piolet
Hkk needle on 4th clip
Jetted for oregon coast
421 serval built by Fast with cleanup port on pump gas
1) What type of aftermarket exhaust do you have? Shearer SB inframes
2) What type of airfilter do you have? K&N Pods with outerwears
3) Are you a) no airbox at all
4) What is your elevation? 923 ASL
5) What size pilot jets are you using? 35
6) What size main jets are you using? 152
7) What temperature is your Banshee jetted for? 60-80ish
8) Do you have a port job?  421 serval cub/cleanup port
9) What kind of carbs? Keihin 35mm pwk air strikers
CGL needles middle clip, air screws 1.5
  • 2 weeks later...
