driftingbanshee Posted May 15, 2014 Report Share Posted May 15, 2014 (edited) 1) What type of aftermarket exhaust do you have? | CPI in frames 2) What type of airfilter do you have? | 2 stage UNI filters 3) Are you running a air box | air box removed 4) What is your elevation? | sea level upto 500 5) What size pilot jets are you using? 30 6) What size main jets are you using? 340 7) What temperature is your Banshee jetted for? | 15 - 30c 8) Do you have a port job? | no 9) What kind of carbs? | stock mikuni >10) What size carbs? | 26mm Edited May 15, 2014 by driftingbanshee Quote Link to comment Share on other sites More sharing options...
350smokey Posted May 19, 2014 Report Share Posted May 19, 2014 Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have? Fatty's 2) What type of airfilter do you have? K&N 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all Stock airbox with snorkle off and vents in lid when below 60F, no lid Above 60F 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 1000ft 5) What size pilot jets are you using? 30 6) What size main jets are you using? 340 7) What temperature is your Banshee jetted for? 80f 8) Do you have a port job? Yes 9) What kind of carbs? Stock 10) What size carbs? 26mm Thanks! Quote Link to comment Share on other sites More sharing options...
Skeletor Posted May 24, 2014 Report Share Posted May 24, 2014 1) What type of aftermarket exhaust do you have? T5's 2) What type of airfilter do you have? K&N with adapter 3) Are you a)running a stock airbox without lid 4) What is your elevation? (If you don't know, go here: http://www.topozone.com )3250ft 5) What size pilot jets are you using?Stock 25 6) What size main jets are you using?280 7) What temperature is your Banshee jetted for?around 80F 8) Do you have a port job? Not yet 9) What kind of carbs? Mikuni 10) What size carbs? Stock Quote Link to comment Share on other sites More sharing options...
ETR174 Posted June 8, 2014 Report Share Posted June 8, 2014 (edited) 1) What type of aftermarket exhaust do you have? | FMF Fatty's 2) What type of airfilter do you have? | UNI Two-Stage Foam filter 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all | A. Stock Setup 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) | 600ft above sea level 5) What size pilot jets are you using? | 27.5 pilots 6) What size main jets are you using? | 270 and 280 mains 7) What temperature is your Banshee jetted for? | 60-90° 8) Do you have a port job? | No 9) What kind of carbs? | Stock Mikuni Carbs 10) What size carbs? | 26mm Thanks! Sent from My LG-LS970 Edited June 8, 2014 by ETR174 Quote Link to comment Share on other sites More sharing options...
tfaith08 Posted July 4, 2014 Report Share Posted July 4, 2014 (edited) 1) What type of aftermarket exhaust do you have? T52) What type of airfilter do you have? ProFlow w/UNI 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all No airbox lid, 4 vents 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 146' ASL 5) What size pilot jets are you using? Stock6) What size main jets are you using? 330 7) What temperature is your Banshee jetted for? 85F 8) Do you have a port job? No 9) What kind of carbs? Stock w/o TORS - Stock needle, 3rd clip, 2.5 turns out 10) What size carbs? Stock Edited July 4, 2014 by tfaith08 Quote Link to comment Share on other sites More sharing options...
biglaaa Posted August 25, 2014 Report Share Posted August 25, 2014 my first post here guys ! just wanna say whatsup and thanks for allowing me to join !!!!! 1) What type of aftermarket exhaust do you have? pro circuit with 304 silencers2) What type of air filter do you have? k&n3) Are you a)running a stock air box with lid stock air box with NO lid c) Stock air box with vents d) no air box at all . B . stock no lid4) What is your elevation? 60ft5) What size pilot jets are you using? 306) What size main jets are you using? 3007) What temperature is your Banshee jetted for?8) Do you have a port job? no9) What kind of carbs? Stock10) What size carbs? Quote Link to comment Share on other sites More sharing options...
lowidenfast Posted August 25, 2014 Report Share Posted August 25, 2014 1) What type of aftermarket exhaust do you have? Toomey T5's2) What type of airfilter do you have? K&N pods3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all/ No air box whatsoever4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 800'5) What size pilot jets are you using? 25's but still questioning my jetting, may go back to larger pilot jets6) What size main jets are you using? 290's. Needle on 3rd position of 67) What temperature is your Banshee jetted for? New to jetting and still trying to get it right but it's hot and humid here. I'd say 90 degree F8) Do you have a port job? Stock port9) What kind of carbs? stock10) What size carbs? 26mm +4 timing, 40:1 race gas mix with 90 octane ethanol free fuel ~105 octane Quote Link to comment Share on other sites More sharing options...
91coupemike Posted September 13, 2014 Report Share Posted September 13, 2014 1) What type of aftermarket exhaust do you have? Toomey t5 2) What type of airfilter do you have? K&n pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all No air box 4) What is your elevation? 660ft 5) What size pilot jets are you using? 45 6) What size main jets are you using? 138 7) What temperature is your Banshee jetted for? 80-100 8) Do you have a port job? No 9) What kind of carbs? Kehin pwk 10) What size carbs? 28mm Pro design cool head 19cc domes Stock reeds, stock intake Are these jets okay? It seemed to run "okay" but I've never owned a banshee before. So what do I know. Quote Link to comment Share on other sites More sharing options...
Leadmonster Posted September 16, 2014 Report Share Posted September 16, 2014 1) What type of aftermarket exhaust do you have? T5 2) What type of airfilter do you have? Uni w/skins 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all. No box 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ). 0-600 5) What size pilot jets are you using? Na 6) What size main jets are you using? 145 7) What temperature is your Banshee jetted for? 60-110 8) Do you have a port job? 10 year old lrd port 9) What kind of carbs? Pwk 10) What size carbs? 30mm 14/40 +4 swing +4 timing Stock stroke motor. Runs like a champ with that old port job . im very happy with this play/dune bike Quote Link to comment Share on other sites More sharing options...
biglaaa Posted October 4, 2014 Report Share Posted October 4, 2014 1) What type of aftermarket exhaust do you have? pc 304s 2) What type of air filter do you have? k&n3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all B . 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) sea level5) What size pilot jets are you using?306) What size main jets are you using?3407) What temperature is your Banshee jetted for? 20-608) Do you have a port job? bored 0ver with 65mm vitos super stock9) What kind of carbs? stock10) What size carbs? stock Quote Link to comment Share on other sites More sharing options...
awblackmamba Posted November 4, 2014 Report Share Posted November 4, 2014 1) What type of aftermarket exhaust do you have? T5's 2) What type of air filter do you have? uni 2 into 1 3) What type of airbox do you have? none 4) Whats your elevation? 700 5) What size pilot jets are you using? 30 6) What size mains are you using? 270 think I need 300's 7) What temperature is your banshee jetted for? 70 8) Do you have a port job? stock 9) What kind of carbs? stock 10) What size carbs? 26mm Quote Link to comment Share on other sites More sharing options...
96warrior Posted December 21, 2014 Report Share Posted December 21, 2014 1) What type of aftermarket exhaust do you have? T5's 2) What type of air filter do you have? K/n 2 into 1 3) What type of airbox do you have? none 4) Whats your elevation? 712ft 5) What size pilot jets are you using? I can't remember! 6) What size mains are you using? 370's 7) What temperature is your banshee jetted for? 70 8) Do you have a port job? Trinity MX/TT port, kinda mild no boyesen ports, center bridge isn't knife edged 9) What kind of carbs? Mikuni TM flat slides, boyesen rad valves too 10) What size carbs? 34mm Quote Link to comment Share on other sites More sharing options...
02banshnyoda Posted December 28, 2014 Report Share Posted December 28, 2014 1) What type of aftermarket exhaust do you have? FMF fattys w/ turbinecore2 2) What type of air filter do you have? STOCK 3) What type of airbox do you have? STOCK 4) Whats your elevation? ~5000ft 5) What size pilot jets are you using? Stock 25s 6) What size mains are you using? 200s 7) What temperature is your banshee jetted for? Idk, for nice days. 8) Do you have a port job? Not that I am aware of, but do have VFORCE4 reeds and bored 0.020" over. 9) What kind of carbs? STOCK, tors delete 10) What size carbs? STOCK Quote Link to comment Share on other sites More sharing options...
rdz367 Posted January 19, 2015 Report Share Posted January 19, 2015 1) What type of aftermarket exhaust do you have? T52) What type of airfilter do you have? K&N PODS3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all K&N PODS^4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 140 ABOVE5) What size pilot jets are you using? UNKNOWN 6) What size main jets are you using? UNKNOWN7) What temperature is your Banshee jetted for? 80 TO 1008) Do you have a port job? MILD DRAG PORT 9) What kind of carbs? KEIHIN PWK10) What size carbs? 33MM Quote Link to comment Share on other sites More sharing options...
ninjaturtle13 Posted January 23, 2015 Report Share Posted January 23, 2015 1) What type of aftermarket exhaust do you have? T5 2) What type of airfilter do you have? 3 inch kNn type... 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all straight filters 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 3,720ft 5) What size pilot jets are you using? 280 6) What size main jets are you using? 25 7) What temperature is your Banshee jetted for? 80 _100 8) Do you have a port job? no port nor polish 9) What kind of carbs? mikuni 10) What size carbs? stock 26mm mikuni Quote Link to comment Share on other sites More sharing options...
