Finch Posted February 3, 2013 Report Share Posted February 3, 2013 should be pretty close Quote Link to comment Share on other sites More sharing options...
Uf21 Posted February 11, 2013 Report Share Posted February 11, 2013 should be pretty close ok thanks Quote Link to comment Share on other sites More sharing options...
Richmrf Posted March 19, 2013 Report Share Posted March 19, 2013 1) What type of aftermarket exhaust do you have? FMF fatty gold 2) What type of airfilter do you have? Single K&N 3) Are you a)running a stock airbox with lid b)stock airbox with NO lid c) Stock airbox with vents d) no airbox. B 4) What is your elevation? 0-500 ft 5) What size pilot jets are you using? 32.5 6) What size main jets are you using? 310 7) What temperature is your Banshee jetted for? 70ish 8) Do you have a port job? Yes 9) What kind of carbs? Stock 10) What size carbs? Stock I'm not so sure about keeping my pilots that big. They worked in Glamis (desert) but now I'm on the east coast with much more humidity. Anyone have suggestions? Quote Link to comment Share on other sites More sharing options...
edoshee Posted April 20, 2013 Report Share Posted April 20, 2013 Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have? cpi inframe drag pipes 2) What type of airfilter do you have? uni pods 3) Are you a)running d) no airbox at all 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 3647 5) What size pilot jets are you using?38 6) What size main jets are you using?152 7) What temperature is your Banshee jetted for?80 to 100 8) Do you have a port job?no 9) What kind of carbs? keihin 10) What size carbs?35 11) needle position is at 5 Thanks! Quote Link to comment Share on other sites More sharing options...
VoOK Posted May 13, 2013 Report Share Posted May 13, 2013 Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have?-----------Paul Turner High Rev 2) What type of airfilter do you have?--------------K&N 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all-------------stock box, no lid 4) What is your elevation? (If you don't know, go here: http://www.topozone.com )-----------------100' 5) What size pilot jets are you using?-------------30 6) What size main jets are you using?--------------------320 7) What temperature is your Banshee jetted for?--------------------70 8) Do you have a port job?------------------------dune port 9) What kind of carbs?--------------------stock 10) What size carbs?-----------------------stock (26mm) 11) Reeds--------------VF-4 Quote Link to comment Share on other sites More sharing options...
Lee_H Posted May 18, 2013 Report Share Posted May 18, 2013 Stock bore and stroke 04 Needles are in the 3rd groove 1) What type of aftermarket exhaust do you have? Toomey TR6 2) What type of airfilter do you have? K&N 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all Stock air box, no lid 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 2877 5) What size pilot jets are you using? 30.5 6) What size main jets are you using? 320 7) What temperature is your Banshee jetted for? 100*F 8) Do you have a port job? No 9) What kind of carbs? Mikuni 10) What size carbs? 26mm Thanks! Quote Link to comment Share on other sites More sharing options...
Lee_H Posted May 18, 2013 Report Share Posted May 18, 2013 99 4 mil cub CEL needles in the 3rd groove V-Force 3 reeds Nology coil +6 timing 40:1 1) What type of aftermarket exhaust do you have? Early CPI in-frames 2) What type of airfilter do you have? Dual K&N pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all No air box 4) What is your elevation? 2877 5) What size pilot jets are you using? 45 6) What size main jets are you using? 160 7) What temperature is your Banshee jetted for? 100 8) Do you have a port job? Light clean up 9) What kind of carbs? Keihin PWK Airstrikers 10) What size carbs? 35mm 2 Quote Link to comment Share on other sites More sharing options...
jscharphorn Posted May 27, 2013 Report Share Posted May 27, 2013 This thread is nice but it sure would be nice to have it separated into categories for the size of your carbs so your not looking at 12 pages of stock carbs looking for the very few that are the same size as you would have, 1 Quote Link to comment Share on other sites More sharing options...
Eighty9shee Posted May 30, 2013 Report Share Posted May 30, 2013 1) What type of aftermarket exhaust do you have? Toomey T5 2) What type of airfilter do you have? K &N dual pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all. No air box at all 4) What is your elevation? 300 Ft. 5) What size pilot jets are you using? 50 6) What size main jets are you using? 160 7) What temperature is your Banshee jetted for? 90+ 8) Do you have a port job? No clue... 9) What kind of carbs? Keihin (PJ) 10) What size carbs? 34 I believe.. Hey everyone, feedback regarding my set up would be much appreciated. Just bought my banshee not too long ago, and the owner didn't tell me much about the guts of the thing. It has two keihin carbs not too sure about the size I looked online and I think the pj series only comes in 34, does anyone know?... Both of which have a choke. Does that mean no choke tube is required? And some advice for the jets would be great, thanks. Quote Link to comment Share on other sites More sharing options...
davidfence101 Posted July 2, 2013 Report Share Posted July 2, 2013 1) What type of aftermarket exhaust do you have? Toomey T5 2) What type of airfilter do you have? pro design 3) running a stock airbox modded 4) What is your elevation? 1500 to 2000 5) What size pilot jets are you using? 25 6) What size main jets are you using? 360 7) What temperature is your Banshee jetted for? 70 to 90 8) Do you have a port job? HJR Dune Play 9) What kind of carbs? stock 10) What size carbs? stock 11) plus 4 timing 12) vforce 4 13) milled stock head .30 14) needle 4th clip Quote Link to comment Share on other sites More sharing options...
Stonytony Posted August 5, 2013 Report Share Posted August 5, 2013 Please copy and paste this along with your answers in your reply, thanks. 1) Vitos fat bastard inframes 2) K&n 3) Stock air box with no lid 4) 400ft perty much sea level 5) no.30 pilots 6) 320 mains 7) 65-80 degrees f 8) Drag/dune port job 9) Stock carbs 10) Stock carbs Quote Link to comment Share on other sites More sharing options...
JasonBourne.Qc Posted September 2, 2013 Report Share Posted September 2, 2013 1) What type of aftermarket exhaust do you have? FMF Fatty Gold + Powercore I 2) What type of airfilter do you have? Dual UNI pods 3) Running CFM aluminium airbox 4) What is your elevation? 0 to 500 5) What size pilot jets are you using? 25 6) What size main jets are you using? 310 7) What temperature is your Banshee jetted for? 10 to 30°C 8) Do you have a port job? Negative 9) What kind of carbs? Stock Mikuni 10) What size carbs? Stock 26mm 11) +4 Timing 12) Vforce 4 13) Coolhead w/ 19cc domes 14) Needle 3th clip Envoyé depuis mon Optimus G en utilisant Tapatalk 4 Quote Link to comment Share on other sites More sharing options...
Young Guns Racing Posted October 1, 2013 Report Share Posted October 1, 2013 03 stock cylinder 4 mil build 1) What type of aftermarket exhaust do you have? shearer sb in frames 2) What air filter? k&n pods 3) no air box 4) What is your elevation? (If you don't know, go here:http://www.topozone.com) 600 5) What size pilot jets are you using? 52 6) What size main jets are you using? 158 7) What temperature is your Banshee jetted for? 70-90 8) Do you have a port job? yes - hjr aggressive dune 4 mil 9) What kind of carbs? 35mm PWK's 10) What size carbs? 35mm 11) +5 Timing 12) Reeds? Vforce 4 13) Coolhead w/ custom cut 4 mil domes on pump fuel 14) Needle and position? CEL on 3rd clip Quote Link to comment Share on other sites More sharing options...
JasonBourne.Qc Posted October 5, 2013 Report Share Posted October 5, 2013 1) What type of aftermarket exhaust do you have? DMC 916 Alien 2) What type of airfilter do you have? Dual UNI pods 3) Running CFM aluminium airbox 4) What is your elevation? 0 to 500 5) What size pilot jets are you using? 25 6) What size main jets are you using? 310 7) What temperature is your Banshee jetted for? 10 to 30°C 8) Do you have a port job? Negative 9) What kind of carbs? Stock Mikuni 10) What size carbs? Stock 26mm 11) +4 Timing 12) Vforce 4 13) Coolhead w/ 19cc domes 14) Needle clip position? 3rd Envoyé depuis mon LG-D803 avec Tapatalk 4 Quote Link to comment Share on other sites More sharing options...
Trashman1973 Posted October 26, 2013 Report Share Posted October 26, 2013 Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have? FMF FATTYS 2) What type of airfilter do you have? K&N 6" PODS 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all NO AIRBOX 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 1000FT 5) What size pilot jets are you using? 27.5 6) What size main jets are you using? 310 7) What temperature is your Banshee jetted for? 75-85 8) Do you have a port job? YES 9) What kind of carbs? STOCK 10) What size carbs? 26MM Thanks! 1 Quote Link to comment Share on other sites More sharing options...
