2wheelturned4 Posted September 20, 2012 Report Share Posted September 20, 2012 1) What type of aftermarket exhaust do you have? FMF fatty with powercore 2 2) What type of airfilter do you have? K&N 3) Are you stock airbox with NO lid 4) What is your elevation? Sea Level 5) What size pilot jets are you using? 25 6) What size main jets are you using? 310 7) What temperature is your Banshee jetted for? 35c 8) Do you have a port job? ? athena 392cc kit 9) What kind of carbs? Stock 10) What size carbs? Stock Quote Link to comment Share on other sites More sharing options...
Bad one ton Posted September 20, 2012 Report Share Posted September 20, 2012 1) What type of aftermarket exhaust do you have? Toomey T-5's 2) What type of airfilter do you have?K&N 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all Stock box no lid 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 5800ft 5) What size pilot jets are you using? 25 6) What size main jets are you using? 280 7) What temperature is your Banshee jetted for? 8) Do you have a port job? No 9) What kind of carbs? Stock 10) What size carbs?26 TON! Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
IceAlmeida Posted September 21, 2012 Report Share Posted September 21, 2012 1) What type of aftermarket exhaust do you have? = T5's 2) What type of airfilter do you have? = K&N DualAirfilter 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all = B stock airbox with proflow adapter for K&N 4) What is your elevation? = 1000FT Ontario Canada 5) What size pilot jets are you using? = 27.5 6) What size main jets are you using? = 280 7) What temperature is your Banshee jetted for? = 50 f - 90 f ????? 8) Do you have a port job? = STOCK JUGS 9) What kind of carbs? = STOCK CARBS 10) What size carbs? = STOCK 26mm 11) STOCK NEEDLE IN 4th clip (worked the best outta the tommey needle and stock needle) Quote Link to comment Share on other sites More sharing options...
traxx2003 Posted September 26, 2012 Report Share Posted September 26, 2012 (edited) 1) What type of aftermarket exhaust do you have? Toomey T-5 2) What type of airfilter do you have? K&N filter Pods w/outerware 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all. 4) What is your elevation? 2200-2300ft above sea level 5) What size pilot jets are you using? 27.5 6) What size main jets are you using? 280 7) What temperature is your Banshee jetted for? 90+ 8) Do you have a port job? No 9) What kind of carbs? Stock 10) What size carbs? Stock 11) Stock Neddle in 3th clip Edited September 26, 2012 by traxx2003 Quote Link to comment Share on other sites More sharing options...
BansheeTeam Posted October 2, 2012 Report Share Posted October 2, 2012 1) What type of aftermarket exhaust do you have? Toomey T-5 2) What type of airfilter do you have? K&N Filter PODs 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all No Airbox 4) What is your elevation? Sea Level 5) What size pilot jets are you using? 25 6) Needle Setting? Dynojet Needle 3rd Groove 7) What size main jets are you using? 300 8) What temperature is your Banshee jetted for? 80 - 100 9) Do you have a port job? NO 10) What kind of carbs? Stock Mikuni 11) Reed Valves? YES V-Force 3 12) What type of fuel are you using) 95 Premium pump gas 13) What gas/oil ratio you use? 36:1 14) What type of premix you use? Carlube 2 Stroke Motorcycle Oil 15) Timing Adjustments? Installed A timing plate but currently set to 0 about to set to +4 degrees soon 16) Boost Bottle? NO ________________________ NEED HELP PLEASE After cleaning my pods and oiling them at WOT on 6th gear I get this bog am I running lean or rich should I install 280's on the main I have a set of 30 pilots should I throw that in as well cause the next bigger jet I have is a 340 what should I do. I wasn't very generous with oiling the filters but i gave it a good amont am I running rich because oil is sealing it or lean because it can breath better now. NOTE it wasn't really dirty when I cleaned it. The Weather is slightly getting cooler and will be mostly around 70 ish soon. Thanks in advance Quote Link to comment Share on other sites More sharing options...
2strokes4u Posted October 4, 2012 Report Share Posted October 4, 2012 1) What type of aftermarket exhaust do you have? CPI BB inframes 2) What type of airfilter do you have? K and N 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) Sea Level 5) What size pilot jets are you using? 52 6) What size main jets are you using? 175 7) What temperature is your Banshee jetted for? 75-80 8) Do you have a port job? Clean up Port on 7mil Cub 9) What kind of carbs? PWK 10) What size carbs? 38mm Quote Link to comment Share on other sites More sharing options...
Colby Posted October 4, 2012 Report Share Posted October 4, 2012 1) What type of aftermarket exhaust do you have? FMF Signature Series 2) What type of airfilter do you have? K&N 3) No Airbox at all 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 3000 5) What size pilot jets are you using? 30 6) What size main jets are you using? 280 7) What temperature is your Banshee jetted for? 75-80 8) Do you have a port job? No 9) What kind of carbs? Stock 10) What size carbs? 26mm 11) Cool Head w/ 19cc domes Quote Link to comment Share on other sites More sharing options...
87BRBanshee Posted October 4, 2012 Report Share Posted October 4, 2012 1) What type of aftermarket exhaust do you have? -Toomey T5's 2) What type of airfilter do you have? -Tommey 2 stage filter 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all - No lid with 6 vents 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) -823 FT 5) What size pilot jets are you using? -27.5 6) What size main jets are you using? -300 7) What temperature is your Banshee jetted for? ?? 8) Do you have a port job? -No 9) What kind of carbs? -Stock 10) What size carbs? -stock Quote Link to comment Share on other sites More sharing options...
martin (arg) Posted October 10, 2012 Report Share Posted October 10, 2012 ) What type of aftermarket exhaust do you have? PRO CIRCUIT 304 PLATINUM 2) What type of airfilter do you have? PRO FLOW PRO DESIGN 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all AIRBOX WITHOUT LID 4) What is your elevation? SEA LEVEL 5) What size pilot jets are you using? 27,5 6) Needle Setting? STOCK ON 5TH POSITION 7) What size main jets are you using? 290 8) What temperature is your Banshee jetted for? 20 °C 9) Do you have a port job? NO 10) What kind of carbs? STOCK 11) Reed Valves? STOCK 12) What type of fuel are you using) 97 PREMIUM 13) What gas/oil ratio you use? I LITER GAS / 250 CC OIL 14) What type of premix you usE? MÁXIMA CASTOR 927 15) Timing Adjustments? DYNA FS CUSTOM MAP ON +4 DEGREES 16) Boost Bottle? MOOSE 17) Spark plugs? NGK BR8ES Quote Link to comment Share on other sites More sharing options...
YelaBanshee Posted October 31, 2012 Report Share Posted October 31, 2012 1) What type of aftermarket exhaust do you have? toomey t-3 2) What type of airfilter do you have? Stock Foam 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all airbox with lid 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 1066 feet 5) What size pilot jets are you using? 25 6) What size main jets are you using? 270 7) What temperature is your Banshee jetted for? 80 8) Do you have a port job? no 9) What kind of carbs? stock 10) What size carbs? stock Quote Link to comment Share on other sites More sharing options...
fat_tony Posted November 5, 2012 Report Share Posted November 5, 2012 1) What type of aftermarket exhaust do you have? fmf gold pc2s 2) What type of airfilter do you have? uni foam 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all stock box vented 4) What is your elevation? 1400 ft 5) What size pilot jets are you using? 27.5 6) What size main jets are you using? 300 7) What temperature is your Banshee jetted for? 75 8) Do you have a port job? no 9) What kind of carbs? Stock Mikuni 10) What size carbs? Stock 12) Do you have a coolhead? yes 13) What brand is your coolhead? chariot 14) What size domes are you using? 19cc 15) What type of fuel are you using) 91 pump gas 16) What gas/oil ratio you use? 40to1 17) What type of premix you use? Maxima Castor 927 18) what reeds and cages ? stock cages hogged out and boysen dual stage reeds Quote Link to comment Share on other sites More sharing options...
20Banshee03 Posted November 21, 2012 Report Share Posted November 21, 2012 (edited) 1) What type of aftermarket exhaust do you have? FMF Gnarley with power core 2 2) What type of airfilter do you have? Pod filters 3) Are you d) no airbox at all 4) What is your elevation?600 5) What size pilot jets are you using? Stock 6) What size main jets are you using? Stock 7) What temperature is your Banshee jetted for? Don't know. 8) Do you have a port job? No 9) What kind of carbs? Stock 10) What size carbs? Stock I'm trying to get an idea on what size jets i need order. I'm thinking 27.5 and then 270-300. How does this sound? Edited November 21, 2012 by 20Banshee03 Quote Link to comment Share on other sites More sharing options...
coryv4 Posted November 21, 2012 Report Share Posted November 21, 2012 1) What type of aftermarket exhaust do you have? dyno port with a turbo 2) What type of airfilter do you have? big ass k&n 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all... custom 4) What is your elevation? 500-700 ft 5) What size pilot jets are you using? 72 6) What size main jets are you using? .118 7) What temperature is your Banshee jetted for? 80F 8) Do you have a port job? no 9) What kind of carbs? keihin pj 10) What size carbs? 34 12) Do you have a coolhead? yes 13) What brand is your coolhead? Noss 14) What size domes are you using? 22cc 15) What type of fuel are you using) alcohol 16) What gas/oil ratio you use? 20:1 17) What type of premix you use? super tech 18) what reeds and cages ? stock 19) what motor? 421 Quote Link to comment Share on other sites More sharing options...
LawDog Posted January 28, 2013 Report Share Posted January 28, 2013 1) What type of aftermarket exhaust do you have? T-5's 2) What type of airfilter do you have? K&N pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all D. no box 4) What is your elevation? 0-1000 ft sea level 5) What size pilot jets are you using? 25.7 6) What size main jets are you using? 300 7) What temperature is your Banshee jetted for? 80-100 F 8) Do you have a port job? no 9) What kind of carbs? stock mikuni's 10) What size carbs? 26's 12) Do you have a coolhead? Yes 13) What brand is your coolhead? Pro Design 14) What size domes are you using? 20 15) What type of fuel are you using) 110 race 16) What gas/oil ratio you use? 32:1 17) What type of premix you use? Klotz Super Quote Link to comment Share on other sites More sharing options...
Uf21 Posted February 3, 2013 Report Share Posted February 3, 2013 1) What type of aftermarket exhaust do you have? DMC 9162) What type of airfilter do you have? K&N with outerwear3) What airbox a)? Stock airbox with lid4) What is your elevation? 3400ft - 4100ft 5) What size pilot jets are you using? 27 pilot6) What size main jets are you using? 280 main7) What temperature is your Banshee jetted for? Wouldnt have a clue. Though I ride mostly in winter to spring.8) Do you have a port job? No9) What kind of carbs? Stock carbs on 2011 banshee10) What size carbs? No clue Does my jetting sound right for my elevation? Quote Link to comment Share on other sites More sharing options...
