What jets are you using? Fill out this form...
1) What type of aftermarket exhaust do you have? T5's
2) What type of airfilter do you have?k/n pods / outerwear
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all A w/prodesign w/out lid and D
4) What is your elevation? (If you don't know, go here: http://www.topozone.com )1200
5) What size pilot jets are you using?27.5
6) What size main jets are you using? 320 w/ pods and 290 w/ box
7) What temperature is your Banshee jetted for?60 to 70
8) Do you have a port job? yes , aggressive trail port
9) What kind of carbs? Mikiuni
10) What size carbs?34
  • 4 weeks later...
2) What type of airfilter do you have? Mull Engineering Venturi Intake Kit, w/8" K&N's and Outer Wears.
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) Sea Level
5) What size pilot jets are you using? 25's
6) What size main jets are you using? 290's
7) What temperature is your Banshee jetted for? 60* - 65*
8) Do you have a port job? No
9) What kind of carbs? Stock Mikuni's
10) What size carbs? 26mm
  • 3 weeks later...
1) What type of aftermarket exhaust do you have? t5
2) What type of airfilter do you have? k&n pods
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all? No Airbox
4) What is your elevation? 600 - 900 ft
5) What size pilot jets are you using? 27.5
7) What temperature is your Banshee jetted for? 80-90
8) Do you have a port job? HJR Mx hardcore
10) What size carbs? Stock
12) Do you have a coolhead? yes
13) What brand is your coolhead? HJR noss machine head
14) What size domes are you using? 21cc
15) What type of fuel are you using) 91 pump gas
16) What gas/oil ratio you use? 32:1
17) What type of premix you use? Maxima Castor 927
1) What type of aftermarket exhaust do you have? FMF Gold Series w PC2
2) What type of airfilter do you have? Modified K&N Filters
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all D
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) Sea level
5) What size pilot jets are you using? 30
6) What size main jets are you using? 340
7) What temperature is your Banshee jetted for? 70-90F
8) Do you have a port job? Aggressive Dune port Advance machine shop in Pa.
10) What size carbs? 26 for the moment.
Thanks!
<br class="Apple-interchange-newline">
1) What type of aftermarket exhaust do you have? FMF Gold's W/Power Core II's
2) What type of airfilter do you have? K&N Filter PODs w/Outerwears
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all? NO AIRBOX
7) What temperature is your Banshee jetted for? 65 - 100
8) Do you have a port job? casting clean up, polished exhaust ports, no port mods
9) What kind of carbs? Stock Mikuni w/TORS Elim.
13) What brand is your coolhead? PRO DESIGN
14) What size domes are you using? 20cc
15) What type of fuel are you using) 93 pump gas
17) What type of premix you use? KLOTZ R-50
I also have Pro-design billet intakes w/NO crossover or boost bottle, and V-Force III's, the engine is also .050 over with Wiseco pro-lites
1) What type of aftermarket exhaust do you have? FMF Fattys w/ power core silencers
3) Are you a)running a stock airbox with lid b)stock airbox with NO lid c) Stock airbox with vents d) no air box? B: stock box, no lid
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) Appx 800 feet above sea level
5) What size pilot jets are you using? 25 stock
6) What size main jets are you using? 260-280 depending on the air temp
7)Needle position? 3rd from the bottom/ stock needle
8) What temperature is your Banshee jetted for? 50-100F
9) Do you have a port job? No
10) What kind of carbs? Stock
11) What size carbs? Stock
12)Mix ratio? 32:1 Amsoil & 110 Octane
I have a slight bog out of the hole but hang on to your ass after that! :bolt:
  • 4 weeks later...
Please copy and paste this along with your answers in your reply, thanks.
FMF
UNi
Stock w/ lid
530 ish
?? 27.5
290
yes
Stock
28
4mill 110 rods.
1) What type of aftermarket exhaust do you have? CPI's
3) What filter setup? POD's
4) What is your elevation? 1100 feet
5) What size pilot jets are you using? 32.5
6.5) What postion is your needle in? 3rd clip
8) Do you have a port job? Yes / Redline Dune Port
  • 2 weeks later...
Toomey T5s
stock
Stock
4) What is your elevation? 300 feet.
5) What size pilot jets are you using? Stock, I am unsure the size.
6) What size main jets are you using? 300
6.5) What postion is your needle in? I'm not sure how to check that
7) What temperature is your Banshee jetted for? I'm not sure
8) Do you have a port job ? No
  • 2 weeks later...
1) What type of aftermarket exhaust do you have? Trinity
2) What type of airfilter do you have?prodesign
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all CUSTOM
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) c level
5) What size pilot jets are you using? 48
6) What size main jets are you using? 152
7) What temperature is your Banshee jetted for? 40-90
8) Do you have a port job? fast dune/fun
9) What kind of carbs? Keh
10) What size carbs? 33
Thanks!
  • 2 weeks later...
1) What type of aftermarket exhaust do you have? SB CPI in frames
2) What type of airfilter do you have? 12" k&n pods
3) no airbox at all CUSTOM
5) What size pilot jets are you using? 42
8) Do you have a port job? Aggressive Dune/Drag and port match case
9) What kind of carbs? pwk
10) What size carbs? 35
  • 5 weeks later...
sb cpi infame
Toomey 1into2 filter
No air box
500 to 1000ft
30
310
Lite a&s racing port work
Stock
26mm ithink?
1) What type of aftermarket exhaust do you have? Pro Circuit
2) What type of airfilter do you have? Pro Design Pro Flow Foam
3) Stock airbox w/ lid, no snorkel
4) What is your elevation? 1100 ft
7) What temperature is your Banshee jetted for? 50-90
8) Do you have a port job? Stock
9) What kind of carbs? stock
10) What size carbs? 26 Stock
Im running a bit rich, could probably go down a size on the main, but id rather be safe than sorry for trail riding.
1) What type of aftermarket exhaust do you have? Fmf Fattys PC2s
2) What type of airfilter do you have? UNI pods w/ outerwears
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all:.........No airbox.
4) What is your elevation? 2000-3000
5) What size pilot jets are you using? 45
6) What size main jets are you using? 150
9) What kind of carbs? Keihin 28mm
10) What size carbs? 28mm
