shakar Posted October 15, 2011 Report Share Posted October 15, 2011 1) What type of aftermarket exhaust do you have? r-2's 2) What type of airfilter do you have? K&N pods 3) Are you running a airbox? No 4) What is your elevation? 333 ft. above sea level 5) What size pilot jets are you using? 27 1/2 6] What size main jets are you using? 330 7) What temperature is your Banshee jetted for? 70+ 8) Do you have a port job? (Yes) mx/trail 9) What kind of carbs? mikuni's 10) What size carbs? 28mm 11) Do you have a coolhead? yes 12) What brand is your coolhead? noss 13) What size domes are you using? 20cc 14) What type of fuel are you using) 1/2 vp 110 1/2 87 pump 15) What gas/oil ratio you use? 40:1 16) What type of premix you use? interceptor Quote Link to comment Share on other sites More sharing options...
clintonior Posted October 17, 2011 Report Share Posted October 17, 2011 (edited) 1) What type of aftermarket exhaust do you have? FMF FATTY 2) What type of airfilter do you have? UNI 3) Are you running? stock airbox with NO lid 4) What is your elevation? 1104 5) What size pilot jets are you using? 30 6) What size main jets are you using? 320 7) What temperature is your Banshee jetted for? 60f 8) Do you have a port job? unlikley 9) What kind of carbs? stock Mikuni 10) What size carbs? 26vm roundslides 11) Do you have a coolhead? nope 12) What brand is your coolhead? NA 13) What size domes are you using? NA 14) What type of fuel are you using) 93AKI pump 15) What gas/oil ratio you use? 26:1 16) What type of premix you use? Poulan synthetic 2-cycle oil Edited October 17, 2011 by clintonior Quote Link to comment Share on other sites More sharing options...
escobar Posted December 27, 2011 Report Share Posted December 27, 2011 1) What type of aftermarket exhaust do you have? stock 2) What type of airfilter do you have? K & N 3) Are you running? stock airbox with NO lid 4) What is your elevation? 900 5) What size pilot jets are you using? 25 6) What size main jets are you using? 220 7) What temperature is your Banshee jetted for? 40f 8) Do you have a port job? no 9) What kind of carbs? stock Mikuni 10) What size carbs? 26vm roundslides 11) Do you have a coolhead? nope 12) What brand is your coolhead? NA 13) What size domes are you using? NA 14) What type of fuel are you using) 87 pump 15) What gas/oil ratio you use? 40:1 16) What type of premix you use? yamalube Quote Link to comment Share on other sites More sharing options...
350 screamer Posted February 14, 2012 Report Share Posted February 14, 2012 Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have? FMF fattys and silencers 2) What type of airfilter do you have? stock uni airfilter 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all....A 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 637ft above sea level 5) What size pilot jets are you using? 27.5 6) What size main jets are you using? 280 7) What temperature is your Banshee jetted for? 50-70 8) Do you have a port job? no 9) What kind of carbs? Mikuni 10) What size carbs? stock Thanks! Quote Link to comment Share on other sites More sharing options...
03banshee20 Posted February 27, 2012 Report Share Posted February 27, 2012 Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have? dmc alien 2) What type of airfilter do you have?uni pod 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all (d) 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 600 ft 5) What size pilot jets are you using? 52 6) What size main jets are you using? 180 7) What temperature is your Banshee jetted for? 70-85 8) Do you have a port job? no 9) What kind of carbs? single khin pwk 10) What size carbs? 36 Thanks! Quote Link to comment Share on other sites More sharing options...
Bansheeboy421 Posted March 6, 2012 Report Share Posted March 6, 2012 1) What type of aftermarket exhaust do you have? FMF fatty and powercore 2 2) What type of airfilter do you have? K&n with alum air box adapter 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all Stock airbox without lid 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 564.3 5) What size pilot jets are you using? 27.5 6) What size main jets are you using? 270 mains 7) What temperature is your Banshee jetted for? do not know 8) Do you have a port job? yes mild i was told 9) What kind of carbs? mikuni 10) What size carbs? 28mm (i think stock) Quote Link to comment Share on other sites More sharing options...
Infamous039 Posted March 7, 2012 Report Share Posted March 7, 2012 1) What type of aftermarket exhaust do you have? RDZ Shearer Inframes 2) What type of airfilter do you have? Uni Pods 3) Are you running? NO AIRBOX 4) What is your elevation? Sea Level 5) What size pilot jets are you using? 45 6) What size main jets are you using? 158 7) What temperature is your Banshee jetted for? 40-50 degrees 8) Do you have a port job? 4mill Dune Port by FAST Racing 9) What kind of carbs? Keihin 10) What size carbs? 33mm PWK 11) Do you have a coolhead? Yes 12) What brand is your coolhead? Noss Machine 13) What size domes are you using? 22cc 4mill domes 14) What type of fuel are you using) 93 pump 15) What gas/oil ratio you use? 32:1 16) What type of premix you use? Castor 927 Quote Link to comment Share on other sites More sharing options...
strokersteve Posted March 27, 2012 Report Share Posted March 27, 2012 1) What type of aftermarket exhaust do you have? DG 2) What type of airfilter do you have? K&N 3) Are you running? air box with no lid 4) What is your elevation? 500 - 800 meters 5) What size pilot jets are you using? 25 6) What size main jets are you using? 310 7) What temperature is your Banshee jetted for? 40-50 degrees 8) Do you have a port job? aggressive trail port 9) bore/stroke ? stock stroke 69mm big bore 10) What kind of carbs? mik 11) What size carbs? 34mm 12) Do you have a coolhead? not yet 13) What brand is your coolhead? N/A 14) What size domes are you using? ? 15) What type of fuel are you using) 91 pump 16) What gas/oil ratio you use? 32:1 17) What type of premix you use? amsoil dominator Quote Link to comment Share on other sites More sharing options...
andrew3160 Posted March 27, 2012 Report Share Posted March 27, 2012 1) What type of aftermarket exhaust do you have? Shearer 2) What type of airfilter do you have? 6" Pods 3) Are you running? No air box 4) What is your elevation? 900 5) What size pilot jets are you using? 48 6) What size main jets are you using? 160 7) What temperature is your Banshee jetted for? 70-80 8) Do you have a port job? Play/Dune 9) bore/stroke? First over on stock cyl, 4 mill short rod 10) What kind of carbs? PWK 11) What size carbs? 35 12) Do you have a coolhead? Yes 13) What brand is your coolhead? Noss 14) What size domes are you using? 21 15) What type of fuel are you using) 91-93 pump 16) What gas/oil ratio you use? 36:1 17) What type of premix you use? Klotz techno plate Quote Link to comment Share on other sites More sharing options...
WYBanshee96 Posted April 2, 2012 Report Share Posted April 2, 2012 Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have? Toomey T5 2) What type of airfilter do you have?UNI FOAM PODS 6" 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all. NO BOX 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ). 6200 5) What size pilot jets are you using?30 6) What size main jets are you using?290 7) What temperature is your Banshee jetted for?70-85F 8) Do you have a port job? NO 9) What kind of carbs?STOCK 10) What size carbs?26 also have chariot billet cages w/ boyessen 2 stage reeds, 4mil stroke, 19cc domes in cool head 168psi. No matter how I ride(dunes or trail) my plugs last all year and are always light chocolate in color. Also one question is missing up there. I run Amsoil intercepter at 4oz per gal.(32:1) Thanks! Quote Link to comment Share on other sites More sharing options...
OhioShee77 Posted April 2, 2012 Report Share Posted April 2, 2012 Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have? DMC Alien 2) What type of airfilter do you have? K&N 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all? Stock airbox 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 750' above sea level 5) What size pilot jets are you using? 28 6) What size main jets are you using?280 7) What temperature is your Banshee jetted for? 70deg F 8) Do you have a port job? no 9) What kind of carbs? VM26 w/TORS eleminator caps 10) What size carbs? 26mm Thanks! Quote Link to comment Share on other sites More sharing options...
kenrick Posted April 5, 2012 Report Share Posted April 5, 2012 1) What type of aftermarket exhaust do you have? i have toomey t4s 2) What type of airfilter do you have? prodesign pro flow 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all....... A 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 777 feet 41.119ºN 81.519ºW 5) What size pilot jets are you using? stock 6) What size main jets are you using? stock 7) What temperature is your Banshee jetted for? 40 ish to 75 ish 8) Do you have a port job? No 9) What kind of carbs? stock with tors mods 10) What size carbs? 26mm Quote Link to comment Share on other sites More sharing options...
Chip M Posted April 8, 2012 Report Share Posted April 8, 2012 (edited) 1) What type of aftermarket exhaust do you have?........ FMF Fatty's PowerCore 2 Silencers 2) What type of airfilter do you have?......... K&N 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all...........A 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ).........@ sea level 5) What size pilot jets are you using?.... 27.5 6) What size main jets are you using?.... 260 7) What temperature is your Banshee jetted for?........ 80 F 8) Do you have a port job? .......no 9) What kind of carbs?.....stock mikuni's 10) What size carbs?....26's Edited April 8, 2012 by Chip M Quote Link to comment Share on other sites More sharing options...
LawDog Posted April 11, 2012 Report Share Posted April 11, 2012 1) What type of aftermarket exhaust do you have? T-5's 2) What type of airfilter do you have? K&N pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all D. no box 4) What is your elevation? 0-1000 ft sea level 5) What size pilot jets are you using? 25.7 6) What size main jets are you using? 300 7) What temperature is your Banshee jetted for? 80-100 F 8) Do you have a port job? yes play 9) What kind of carbs? stock mikuni's 10) What size carbs? 26's 12) Do you have a coolhead? Yes 13) What brand is your coolhead? Pro Design 14) What size domes are you using? ? 15) What type of fuel are you using) 93 pump 16) What gas/oil ratio you use? 50:1 17) What type of premix you use? Klotz Super Quote Link to comment Share on other sites More sharing options...
Yotalac Posted April 12, 2012 Report Share Posted April 12, 2012 (edited) 1) What type of aftermarket exhaust do you have? Pro Circuit 2) What type of airfilter do you have? K&N Filter PODs 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all No Airbox 4) What is your elevation? 600 - 900 ft 5) What size pilot jets are you using? 27.5 6) What size main jets are you using? 330 7) What temperature is your Banshee jetted for? 80 - 100 8) Do you have a port job? yes (play port from FAST) also a Head w/ 21cc domes 9) What kind of carbs? Stock Mikuni 10) What size carbs? Stock 12) Do you have a coolhead? yes 13) What brand is your coolhead? FAST 14) What size domes are you using? 21cc 15) What type of fuel are you using) 93 pump gas 16) What gas/oil ratio you use? 32:1 17) What type of premix you use? Maxima Castor 927 Edited April 12, 2012 by Yotalac Quote Link to comment Share on other sites More sharing options...
