What jets are you using? Fill out this form...
Please copy and paste this along with your answers in your reply, thanks.
1) What type of aftermarket exhaust do you have? toomys tt5
2) What type of airfilter do you have? k & n
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all stock with no lid
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 300 feet
5) What size pilot jets are you using? ???? the jet kit that comes with the fmf pipe kit , it the only on the f**ken dealer add in is books
6) What size main jets are you using? ??
7) What temperature is your Banshee jetted for? 70 f
8) Do you have a port job? no
9) What kind of carbs? stock
10) What size carbs? stock
Thanks!
it runing like there not enough gaz in the carbs after 10 or 15 second .
  • 2 weeks later...
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all
K&N pods
800'
48
158... CEL needles on middle clip
70+ F
421 serval w/ clean up
Keihin PWK series
35mm
1) What type of aftermarket exhaust do you have? FMF fatty's - powercore 2 silencers
2) What type of airfilter do you have? K&N
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all? Stock Airbox NO Lid
4) What is your elevation? 2000ft ASL
5) What size pilot jets are you using? 27.5
6) What size main jets are you using? 320
7) What temperature is your Banshee jetted for? 10-25 Degrees Celcius
8) Do you have a port job? HJR Dune/Play
9) What kind of carbs Stock
10) What size carbs? 26mm (stock)
  • 3 weeks later...
1) What type of aftermarket exhaust do you have? FMF SST's
2) What type of airfilter do you have? UNI Filter
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all. stock box without lid
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 585
5) What size pilot jets are you using? 30 pilot
6) What size main jets are you using? 280 main
7) What temperature is your Banshee jetted for? 70 degrees+
8) Do you have a port job? mild port work
9) What kind of carbs? stock carb with a little machine work to open up the throats
  • 2 weeks later...
1) What type of aftermarket exhaust do you have? Rockets R2's
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all. No airbox at all
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 59 feet
5) What size pilot jets are you using? 52pilot
6) What size main jets are you using? 160main
8) Do you have a port job? dune port play
9) What kind of carbs? keihin
10) What size carbs? 34pjs
1) What type of aftermarket exhaust do you have? - CPI inframe
2) What type of airfilter do you have? - K&N
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all - PODS
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 850
5) What size pilot jets are you using? 45
6) What size main jets are you using? 158
7) What temperature is your Banshee jetted for? 75f
8) Do you have a port job? - yes HJR Dune Hill Shouter
9) What kind of carbs? -keihin A/S pwk
10) What size carbs? 35mm
1) Paul Turner Mids/ Cascade Silencers
2) K&N Pod
3) no airbox at all
4) sea level
5) 50
6) 195
7) 60-80
8) mild trinity port
9) Single Keihin PWK
10) 35mm
  • 3 weeks later...
1) What type of aftermarket exhaust do you have?-------- Toomey T5
2) What type of airfilter do you have?------- K+N Filter w/ Adaptor Plate
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all--------- K+N Airbox Lid w/ Drycharger
4) What is your elevation? Sea level - 750ft
5) What size pilot jets are you using? ---- 45
6) What size main jets are you using?---- 150
7) What temperature is your Banshee jetted for? -----77 degrees F
8) Do you have a port job? ----- Trail port by F.A.S.T.
9) What kind of carbs?------ PWK
10) What size carbs? 30mm
  • Like 1
1) What type of aftermarket exhaust do you have? = Vito's Fat Bastards
2) What type of airfilter do you have? = K & N with outer wear
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all = Yes airbox / No lid
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) = 546 FT
5) What size pilot jets are you using? = 52
6) What size main jets are you using? = 400
7) What temperature is your Banshee jetted for? = 80 to 100F
8) Do you have a port job? = MX
9) What kind of carbs? = Mikuni
10) What size carbs? = 28MM
1) What type of aftermarket exhaust do you have?no
2) What type of airfilter do you have? im getting dual k&n pods
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all. stock air box with lid
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 300ft
5) What size pilot jets are you using?stock
6) What size main jets are you using?220
7) What temperature is your Banshee jetted for? i think below 50f degrees but i will be runing it above 68f degrees
8) Do you have a port job?no
9) What kind of carbs?stock
Thanks!
Edited by tipn22
  • 3 weeks later...
1) What type of aftermarket exhaust do you have?........ Stock Mids - FMF Powercore 2 silencers
2) What type of airfilter do you have?........ K&N
3) Are you a)running.......... Stock Airbox NO Lid sometime with lid
4) What is your elevation?....... 250 ft ASL
5) What size pilot jets are you using?.......... Stock 25
6) What size main jets are you using?....... 260
7) What temperature is your Banshee jetted for?......... 75*
8) Do you have a port job?........No
9) What kind of carbs......... Stock
10) What size carbs?.......... 26mm (stock)
  • 4 weeks later...
1) What type of aftermarket exhaust do you have? DMC Alien
2) What type of airfilter do you have? Pro Flow design adapter and K&N filter
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all Stock airbox w/out lid
4) What is your elevation? (If you don't know, go here: http://www.topozone.com )885 feet
6) What size main jets are you using?200
7) What temperature is your Banshee jetted for? 50-85 degrees
9) What kind of carbs? Stock Mikoni 26VM
Thanks!
  • 2 weeks later...
**You needed to also ask if a aftermarket head with domes are being used.** (Stock size domes)
1) What type of aftermarket exhaust do you have? (FMF Fatty)
2) What type of airfilter do you have? (K&N)
3) Are you running a airbox (yes stock airbox with lid snorkel removed)
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) (750ft)
5) What size pilot jets are you using? (30)
6) What size main jets are you using? (280)
7) What temperature is your Banshee jetted for? (Summer 70-90)
8) Do you have a port job? (Yes)
9) What kind of carbs? (Stock)
10) What size carbs? (26mm)
1) What type of aftermarket exhaust do you have? SB IF Shearers
2) What type of airfilter do you have? K&N pods
3) Are you running a airbox? No
4) What is your elevation? 82 ft. above sea level
6)What type of needles are you using? CEG mid clip position
7) What size main jets are you using? 160
8) What temperature is your Banshee jetted for? 70+
9) Do you have a port job? (Yes) HJR dune/play
10) What kind of carbs? Keihin
11) What size carbs? 34mm PJ's
12) Do you have a coolhead? yes
13) What brand is your coolhead? Chariot
14) What size domes are you using? 21cc
15) What type of fuel are you using) 93 pump gas
16) What gas/oil ratio you use? 32:1
17) What type of premix you use? Klotz Supertechniplate
