Snopczynski Posted October 7, 2010 Report Share Posted October 7, 2010 1) What type of aftermarket exhaust do you have? Pro Circuits 2) What type of airfilter do you have? K&N 3) Air Filter set: Running open pod filters with outerwears. 4) What is your elevation? Sea Level 5) What size pilot jets are you using? 27.5 6) What size main jets are you using? 370-380 depending on outside temperature. 7) What temperature is your Banshee jetted for? 380 for 60 degrees and below, 370 in Summertime. 8) Do you have a port job? Yes 9) What kind of carbs? Mikuni TM's (flat slide) 10) What size carbs? 28mm 11) Needles? N68A needles in center clip position. 2.5 Slide cutout on these carbs for a banshee. Quote Link to comment Share on other sites More sharing options...
gotta_goatsfast Posted October 17, 2010 Report Share Posted October 17, 2010 1) What type of aftermarket exhaust do you have? Toomey T5s 2) What type of airfilter do you have? Unifilter with outerwear 3) Air Filter set: Pod filters 4) What is your elevation? 750' 5) What size pilot jets are you using? Keihin 50 6) What size main jets are you using? Keihin 152 7) What temperature is your Banshee jetted for? 70-90 degrees 8) Do you have a port job? No 9) What kind of carbs? OKO 10) What size carbs? 30mm 11) Needles? Center Quote Link to comment Share on other sites More sharing options...
bounty banshee Posted October 26, 2010 Report Share Posted October 26, 2010 Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have?cpi 2) What type of airfilter do you have?k&n 2 single flters 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all 4) What is your elevation? (If you don't know, go here: http://www.topozone.com )320metres 1049.9ft 5) What size pilot jets are you using?30 6) What size main jets are you using?320 7) What temperature is your Banshee jetted for? 8) Do you have a port job? 9) What kind of carbs? 10) What size carbs? Thanks! Quote Link to comment Share on other sites More sharing options...
bounty banshee Posted October 26, 2010 Report Share Posted October 26, 2010 Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have?cpi 2) What type of airfilter do you have?k&n 2 single flters 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all 4) What is your elevation? (If you don't know, go here: http://www.topozone.com )320metres 1049.9ft 5) What size pilot jets are you using?30 6) What size main jets are you using?320 7) What temperature is your Banshee jetted for? 8) Do you have a port job?milled head 9) What kind of carbs?mikuni 10) What size carbs?stock mikuni Thanks! Quote Link to comment Share on other sites More sharing options...
252wheelieking Posted November 21, 2010 Report Share Posted November 21, 2010 1) What type of aftermarket exhaust do you have?T5's 2) What type of airfilter do you have?K&N filter pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at allD no airbox at all 4) What is your elevation? (If you don't know, go here: http://www.topozone.com )sealevel 5) What size pilot jets are you using?48 6) What size main jets are you using?158 7) What temperature is your Banshee jetted for?70-90 degrees 8) Do you have a port job?HJR dune/play port 9) What kind of carbs?Keihin PJ's 10) What size carbs?34mm 11) How many turns out? .5 Quote Link to comment Share on other sites More sharing options...
shee4speed Posted January 22, 2011 Report Share Posted January 22, 2011 (edited) Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have? Shearer SB inframes 2) What type of airfilter do you have? K & N pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all None 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 1800 5) What size pilot jets are you using? 50-- CEL middle clip 6) What size main jets are you using? 152 7) What temperature is your Banshee jetted for? 60- 70 8) Do you have a port job? HJR 9) What kind of carbs? PWK 10) What size carbs? 35 Edited January 22, 2011 by shee4speed Quote Link to comment Share on other sites More sharing options...
agnmotorsports Posted January 30, 2011 Report Share Posted January 30, 2011 1) What type of aftermarket exhaust do you have? 2) What type of airfilter do you have? 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all stock air box no lid 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 995 feets 5) What size pilot jets are you using? stock 25 6) What size main jets are you using? 290 with the stock needle in the 4th clip 7) What temperature is your Banshee jetted for? 290 on summer 300=310 on winter 8) Do you have a port job? nope 9) What kind of carbs? stock 10) What size carbs? stock Quote Link to comment Share on other sites More sharing options...
bikerbboy Posted January 31, 2011 Report Share Posted January 31, 2011 1) What type of aftermarket exhaust do you have? t5s 2) What type of airfilter do you have?3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all 1 into 2 filter open 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) sea lvl 5) What size pilot jets are you using? 45s 6) What size main jets are you using? 390s 7) What temperature is your Banshee jetted for? 8) Do you have a port job? 70-80 9) What kind of carbs? stock 10) What size carbs? 11) Premix ratio? 32.1 Quote Link to comment Share on other sites More sharing options...
sstaton1983 Posted February 3, 2011 Report Share Posted February 3, 2011 1) What type of aftermarket exhaust do you have? t4s 2) What type of airfilter do you have? uni with prefilter 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all airbox no lid 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 700ft 5) What size pilot jets are you using? 25 6) What size main jets are you using? 350 7) What temperature is your Banshee jetted for? winter in ok. 8) Do you have a port job? no 9) What kind of carbs? stock 10) What size carbs? stock Quote Link to comment Share on other sites More sharing options...
Toybreaker Posted February 8, 2011 Report Share Posted February 8, 2011 1) What type of aftermarket exhaust do you have? FMF Fatty (mine) T5 (hers) 2) What type of airfilter do you have? K&N with outerwear (both) 3) Are you a stock airbox with NO lid (both) 4) What is your elevation? -20 to 250 5) What size pilot jets are you using? 27.5 (both) 6) What size main jets are you using? 270 (hers) 280 (mine) 7) What temperature is your Banshee jetted for? 90F 8) Do you have a port job? no 9) What kind of carbs? stock 10) What size carbs? stock Quote Link to comment Share on other sites More sharing options...
gonecheenin Posted February 23, 2011 Report Share Posted February 23, 2011 Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have? -Dynoport 2 into 1 with Big core Barker silencer 2) What type of airfilter do you have? -K&N on Prodesign adaptor with outerwear 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all -Stock airbox without lid in summer & with lid on in winter (so I don't have to rejet for the colder air) 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) -Right around 1600 feet (Vandergrift, PA 15690) 5) What size pilot jets are you using? -Factory with air screws 1/4 turn in from stock 6) What size main jets are you using? -290 mains (which is just a little fat, gonna try 280's this summer) 7) What temperature is your Banshee jetted for? -70 to 80 degree's 8) Do you have a port job? -No 9) What kind of carbs? -Stock Mikuni round slides 10) What size carbs? -26mm I also have 4 degree's advanced timing and V-Force 3 reeds Quote Link to comment Share on other sites More sharing options...
jerzy609 Posted March 5, 2011 Report Share Posted March 5, 2011 Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have?pro circuit pipe and silencer 2) What type of airfilter do you have?k&n 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all =b 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 500ft. asl 5) What size pilot jets are you using?27.5 6) What size main jets are you using? 310 7) What temperature is your Banshee jetted for? 30f 8) Do you have a port job? no 9) What kind of carbs? mikuni 10) What size carbs? 26 Thanks! Quote Link to comment Share on other sites More sharing options...
dcalsv02 Posted March 16, 2011 Report Share Posted March 16, 2011 1) What type of aftermarket exhaust do you have? Paul Turner's mid 2) What type of airfilter do you have? Dual K&N's 3) no airbox at all 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) sea level 5) What size pilot jets are you using? Stock, (need to change, won't idle 6) What size main jets are you using? 310's 7) What temperature is your Banshee jetted for? 65-80 8) Do you have a port job? Trintiy 9) What kind of carbs? Stock 10) What size carbs? Stock Quote Link to comment Share on other sites More sharing options...
Killswitch69 Posted March 29, 2011 Report Share Posted March 29, 2011 1) What type of aftermarket exhaust do you have? T5 2) What type of airfilter do you have? K&N 3) Are you a)running a stock airbox with K&N Powerlid 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) Sea level to 1000ft 5) What size pilot jets are you using? 30 Vito's needle in middle 6) What size main jets are you using? 340 7) What temperature is your Banshee jetted for? 80 8) Do you have a port job? Dune port 9) What kind of carbs? Stock 10) What size carbs? Stock Vito's 66mm 10 port jugs at 160psi compression (110 race fuel), Cool head, +4 timing advance. Could go down one or two sizes on pilot as it is a little rich on bottom. Quote Link to comment Share on other sites More sharing options...
RollinRhino Posted April 3, 2011 Report Share Posted April 3, 2011 (edited) 1) What type of aftermarket exhaust do you have? Pro Circuit 2) What type of airfilter do you have? K&N 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all B 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 800 ft ASL 5) What size pilot jets are you using? 25 6) What size main jets are you using? 320 7) What temperature is your Banshee jetted for? 70* 8) Do you have a port job? Yes 9) What kind of carbs? Mikunis (R5s) 10) What size carbs? 28.5 Edited April 3, 2011 by RollinRhino Quote Link to comment Share on other sites More sharing options...
