vortechblown306 Posted August 12, 2008 Report Posted August 12, 2008 Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have? 2) What type of airfilter do you have? 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 5) What size pilot jets are you using? 6) What size main jets are you using? 7) What temperature is your Banshee jetted for? 8) Do you have a port job? 9) What kind of carbs? 10) What size carbs? Thanks! 7 Quote
TeamRealtreeHD Posted August 12, 2008 Report Posted August 12, 2008 1) What type of aftermarket exhaust do you have? Trinity Stage IV (Very similar to T5) 2) What type of airfilter do you have? K&N pods 6" 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 1200 ft. 5) What size pilot jets are you using? 50 pilots, air screw 1.5 turns out 6) What size main jets are you using? 155 mains 7) What temperature is your Banshee jetted for? 70-85 degrees 8) Do you have a port job? Herr Jugs Racing Hot Hillshooter port 9) What kind of carbs? Keihin PWK 10) What size carbs? 33mm's Quote
ASRBanshee Posted August 12, 2008 Report Posted August 12, 2008 1) What type of aftermarket exhaust do you have? DMC Aliens 2) What type of airfilter do you have? K&N & Powerlid 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all/ Stock airbox Filter lid 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 1200' 5) What size pilot jets are you using? 30 6) What size main jets are you using? 310 7) What temperature is your Banshee jetted for? 70-90 8) Do you have a port job? Stock port 9) What kind of carbs? stock 10) What size carbs? 26mm Quote
THE GRIM RIPPER Posted August 13, 2008 Report Posted August 13, 2008 1) What type of aftermarket exhaust do you have? Toomey T5's 2) What type of airfilter do you have? K&N with pro flow adapter 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all B 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) Sea Level 5) What size pilot jets are you using? 29's 6) What size main jets are you using? 330's I AM RICH RIGHT NOW THOUGH!! (by one or two sizes) 7) What temperature is your Banshee jetted for? 70 Degrees 8) Do you have a port job? Na 9) What kind of carbs? Stockersssssss 10) What size carbs? 1 Quote
dz06shee Posted August 13, 2008 Report Posted August 13, 2008 1) What type of aftermarket exhaust do you have? Toomey T5's 2) What type of airfilter do you have? K&N with flow adapter 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all Stock Airbox with NO lid 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) Sea Level 5) What size pilot jets are you using? 25s 6) What size main jets are you using? 300 (perfect i think?) 7) What temperature is your Banshee jetted for? 20-30 degress C 8) Do you have a port job? No 9) What kind of carbs? Standard Mikunis 10) What size carbs? Standard Quote
mopar1rules Posted August 13, 2008 Report Posted August 13, 2008 (edited) 1) What type of aftermarket exhaust do you have? FMF FATTYS w/ POWERCORE II SILENCERS 2) What type of airfilter do you have? UNI-FILTER 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all STOCK BOX W/SNORKEL REMOVED AND LID SLOTTED 4) What is your elevation? 900 FT ASL 5) What size pilot jets are you using? 25 6) What size main jets are you using? 360 7) What temperature is your Banshee jetted for? 50-60 DEG FERENHEIT 8) Do you have a port job? YES, STAGE 3 RACE LOGIC 9) What kind of carbs? STOCK 10) What size carbs? 26MM 11) How many turns out on air screws? 2-1/2 Edited August 13, 2008 by mopar1rules Quote
Wildcardracing Posted August 13, 2008 Report Posted August 13, 2008 Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have? 2) What type of airfilter do you have?3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 5) What size pilot jets are you using? 6) What size main jets are you using? 7) What temperature is your Banshee jetted for? 8) Do you have a port job? 9) What kind of carbs? 10) What size carbs? 11) Premix ratio? Thanks! 1) What type of aftermarket exhaust do you have? (CPI Inframes) 2) What type of airfilter do you have?(Uni pods w/outerwears) 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) (5000 ft.) 5) What size pilot jets are you using? (25....stock) 6) What size main jets are you using? (310's) 7) What temperature is your Banshee jetted for? (80 deg F.) 8) Do you have a port job? (Aggressive dune port 196 deg ex- 125.5 deg trans) 9) What kind of carbs? (mikuni) 10) What size carbs? (VM 26...stock) 11) Premix ratio? (40:1) Quote
slc_hillshooter Posted August 13, 2008 Report Posted August 13, 2008 1) What type of aftermarket exhaust do you have? Shearer Inframe Small bore 2) What type of airfilter do you have? K&N's 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all No Box 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 4500 feet 5) What size pilot jets are you using? 50 6) What size main jets are you using? 220 with power jets, gas 7) What temperature is your Banshee jetted for? hot and dry 8) Do you have a port job? yes 9) What kind of carbs? 34TM mikuni 10) What size carbs? 34 Quote
mercury65 Posted August 13, 2008 Report Posted August 13, 2008 1) What type of aftermarket exhaust do you have? small bore shearer in frames 2) What type of airfilter do you have?pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 5000 ft 5) What size pilot jets are you using? 42 2 tuns out 6) What size main jets are you using?155 cgl neddle 7) What temperature is your Banshee jetted for? 60 deg f 8) Do you have a port job? yep stock stroke 9) What kind of carbs?pwk 10) What size carbs?33 this is a good idea but some things need added, stroke is a big one, and neddle Quote
chevrolet banshee Posted August 13, 2008 Report Posted August 13, 2008 (edited) 1) What type of aftermarket exhaust do you have? FMF fatty's 2) What type of airfilter do you have? K&N pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all D no air box 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 2500 feet 5) What size pilot jets are you using? 55 1.75 turns out 6) What size main jets are you using? 155 middle clip on the needle 7) What temperature is your Banshee jetted for? 60-100 F 8) Do you have a port job? nope 9) What kind of carbs? Kehin PWK's 10) What size carbs? PWK 35mm's Chevshee Edited August 13, 2008 by chevrolet banshee 1 Quote
bellracing2 Posted August 13, 2008 Report Posted August 13, 2008 1) What type of aftermarket exhaust do you have?...........dynoport 2 into 1 2) What type of airfilter do you have?..................stock 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all..........................stock airbox with lid on 4) What is your elevation? 800 ft asl 5) What size pilot jets are you using?..................stock 6) What size main jets are you using? ..................190s 7) What temperature is your Banshee jetted for?............70deg f 8) Do you have a port job?............no 9) What kind of carbs?.............stock 10) What size carbs?.............stock Quote
mopar1rules Posted August 18, 2008 Report Posted August 18, 2008 lets keep the setups coming :biggrin: Quote
vortechblown306 Posted August 18, 2008 Author Report Posted August 18, 2008 lets keep the setups coming :biggrin: :beer: Quote
Michael Jackson Posted August 18, 2008 Report Posted August 18, 2008 (edited) ) What type of aftermarket exhaust do you have? t5 2) What type of airfilter do you have? k&n 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all lid with big 8x4" hole cut through both layers, snorkel off 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) ride at 500-1000 ft 5) What size pilot jets are you using? stock 6) What size main jets are you using? 280 7) What temperature is your Banshee jetted for? 70+ 8) Do you have a port job? stock 9) What kind of carbs? stock 10)toomey needle 3rd clip 11) 1 1/2 turns on air fuelscreqs Edited August 18, 2008 by Michael Jackson 1 Quote
jbooker82 Posted August 19, 2008 Report Posted August 19, 2008 1) What type of aftermarket exhaust do you have? CPI Small Bore Inframe 2) What type of airfilter do you have? 6" K&N Clamp on POD's 3)No Airbox at all 4) What is your elevation? 2,400 Ft above Sea Lever 5) What size pilot jets are you using? 45 to 48's Depending on Air Temperature. 45's most of the time 6) What size main jets are you using? 155 7) What temperature is your Banshee jetted for? 80 Degrees 8) Do you have a port job? Patriot Racing 4mill Drag Ported Stroker 9) What kind of carbs? Keihin PWK 33's 10) What size carbs? 33 mm 1 Quote
