Rollerstarter Posted August 12, 2008 Report Share Posted August 12, 2008 im recently bought cub and i need to polish them so how to polish a cub materiel need and tips to find mirror finish on my cub Quote Link to comment Share on other sites More sharing options...
bansheesickness Posted August 12, 2008 Report Share Posted August 12, 2008 meat head did a nice rite up on polishing http://www.bansheehq.com/forums/index.php?...=polishing+jugs Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted August 12, 2008 Report Share Posted August 12, 2008 To do it right, you'll need some tools....bench grinder, die grinder, roloc pads (3M preferred), sandpaper, various sized buffing wheels, and a couple different compounds. If you don't have these tools, it's worth it to send it to cascade and let them polish it for a couple hundred bucks, since you'll spend that to buy the tools needed to get the job done. But, you'll polish the cylinders just as you would any aluminum surface, the end result will be as good as the prep work put into the job. Quote Link to comment Share on other sites More sharing options...
INFINITIED Posted August 12, 2008 Report Share Posted August 12, 2008 To do it right, you'll need some tools....bench grinder, die grinder, roloc pads (3M preferred), sandpaper, various sized buffing wheels, and a couple different compounds. If you don't have these tools, it's worth it to send it to cascade and let them polish it for a couple hundred bucks, since you'll spend that to buy the tools needed to get the job done. But, you'll polish the cylinders just as you would any aluminum surface, the end result will be as good as the prep work put into the job. HOW DO YOU MAINTAIN THIS .. I HAVE A BIKE WITH A POLISHED BLOCK AND HEADS... IF THIS THING HITS A WATER OR MUD .. WHAT WORKS BEST TO CLEAN IT WITHOUT LEAVING THE ALUMIUM WHITE IN COLOR ??? Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted August 12, 2008 Report Share Posted August 12, 2008 get some aluminum or billet polish to bring back the sexy sexy once the part starts to fade Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted August 12, 2008 Report Share Posted August 12, 2008 HOW DO YOU MAINTAIN THIS .. I HAVE A BIKE WITH A POLISHED BLOCK AND HEADS... IF THIS THING HITS A WATER OR MUD .. WHAT WORKS BEST TO CLEAN IT WITHOUT LEAVING THE ALUMIUM WHITE IN COLOR ??? I USE SIMPLE GREEN TO REMOVE THE DIRT THEN YOU USE WHATEVER ALUMINUM POLISH YOU PREFER TO KEEP IT SHINING Quote Link to comment Share on other sites More sharing options...
Hilarious Posted August 13, 2008 Report Share Posted August 13, 2008 (edited) I USE SIMPLE GREEN TO REMOVE THE DIRT THEN YOU USE WHATEVER ALUMINUM POLISH YOU PREFER TO KEEP IT SHINING LOL Edited August 13, 2008 by Hilarious Quote Link to comment Share on other sites More sharing options...
INFINITIED Posted August 13, 2008 Report Share Posted August 13, 2008 (edited) I USE SIMPLE GREEN TO REMOVE THE DIRT THEN YOU USE WHATEVER ALUMINUM POLISH YOU PREFER TO KEEP IT SHINING simple green is what i normally use , i thought there might have been some else .. not sure if the enviormentally safe formula works as good as the old one !! loll sorry for the caps .... Edited August 13, 2008 by INFINITIED Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 13, 2008 Report Share Posted August 13, 2008 Believe it or not...K&N Air filter cleaner works AWESOME to remove the dirt as well. If I get a little dirt on my carbs, it's hard to get in the little crevices, etc. I spray on the K&N Cleaner, let it sit for 5 minutes, no scrubbing...hose it off. I was absolutely amazed.... Quote Link to comment Share on other sites More sharing options...
Hilarious Posted August 13, 2008 Report Share Posted August 13, 2008 simple green is what i normally use , i thought there might have been some else .. not sure if the enviormentally safe formula works as good as the old one !! loll sorry for the caps .... i have a jug of that enviromentally challenged simple green that you speak of and it does work well. Quote Link to comment Share on other sites More sharing options...
cornfeedbanshee Posted December 27, 2008 Report Share Posted December 27, 2008 SIMPLE GREEN ONLY! won't fade polishing Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted December 27, 2008 Report Share Posted December 27, 2008 here ya go!! these guys did mine afor around 100 bones... awesome job and fast trunaround!! www.precisepolishing.net Quote Link to comment Share on other sites More sharing options...
Stellar Performance Posted December 27, 2008 Report Share Posted December 27, 2008 :kiss: I USE SIMPLE GREEN TO REMOVE THE DIRT THEN YOU USE WHATEVER ALUMINUM POLISH YOU PREFER TO KEEP IT SHINING LOL simple green is what i normally use , i thought there might have been some else .. not sure if the enviormentally safe formula works as good as the old one !! loll sorry for the caps .... Believe it or not...K&N Air filter cleaner works AWESOME to remove the dirt as well.If I get a little dirt on my carbs, it's hard to get in the little crevices, etc. I spray on the K&N Cleaner, let it sit for 5 minutes, no scrubbing...hose it off. I was absolutely amazed.... :biggrin: :cool: :ermm: :geek: :happy: :kiss: :laugh: :mad: :ninja: :ohmy: THATS JUST TOO FUNNY!!! Quote Link to comment Share on other sites More sharing options...
Bill Posted December 27, 2008 Report Share Posted December 27, 2008 I polished my stockers and it was A bitch, the hardest part was sanding all the rough casting down smooth. Polishing it is the easy part. :biggrin: Quote Link to comment Share on other sites More sharing options...
