Idle adjustment w/ TORS removed. Where?
When you elimate the Throttle overide setup you must drill and tap new idle screws into the side of the carb b/c your idle adjustment before was in the TORS system...
Lokk on the side of the carb, there should be a flathead and jamnut.. If thats not there someone never took the time to make thier idle adjustable
It should have idle screws facing the outside of each carb (LH one on left, RH one on right), but you have to drill & tap those when installing a TORS removal kit so the previous owner might not have done it:
You can use the cable adjusters on the tops but they won't work well, Toomey and others should sell just that part of the kit, it would be worth doing...
Thanks to all for the replies!
The PO never did it. Any input on the best place to get them?
Edit; never mind that last part. I missed the part where you mentioned Toomey should sell them.
I'll check them out.
Thanks!
Edited by Pincushion
