Help Shee Won't idle
RACERMB
Well, I'd say your carbs probably need to be cleaned and synched. If you know your setup and jetting you should post that up in the jetting section and somebody can tell you if your close or not. I don't think it's related to the shifter return spring. Also, have you done away with the TORS? If not, I would suggest doing that it will save you a ton of headaches.
shee does not start hard pull the chokes on and one or two kicks and shee fires right up cold and no choke one kick when warm. pilot jets have not benn cleaned for about 6 months. air and idle was fine problem just started all of a sudden riding down a trail stopped at a cross road and stalled at idle bam no more idle. tors have been removed fist thing done when i got the bike. replaced staock carbs with 34mm pjs about a year ago.
Edited by RACERMB
