setting up shock for extended swinger
STINKYDELUXE
Revalving changes the way the shock reacts. You will see and improvement in traction and ride control. A new spring is important in keeping everything working together properly. Think of the valving as the brain and the spring as the muscle. If you run without the correct spring rate likely you'll wear the shock out sooner and possibly render it un-rebuildable.
Shane
Shane
I ran a stock shock on a +6 w/no problems... duned it and drag raced it, just no big air. Any longer than 6 and all bets are off.
Edited by sheefreak
  • 2 weeks later...
i would take the add on 2" out of it, like fred was saying. that thing sits so soft right now. adn we tried it with the r6 shock. it was better but still super low. what bout just running the stock swinger till you can get a works that is set up for you and the +6? just a thought..... :ermm:
