Case Saver?
+1 for the TM. :thumbsup: I believe it will take up to a 15t counter sprocket, but if you need more room you can just grind away some extra material to make it fit a 16t.
I have the same one and it started leaking gear case oil right after installation. It requires removal of the stock shift drum cover. Just FYI. I ahve to remove mine and see what it will take to seal it.
SP
I have the stock shift drum cover and it works fine with the case saver, and doesn't leak...?
Edited by AssWhore
I used to have a DG billet one.. On a 13tooth sproket I pitch the chain, it balled up and ran my case saver right through my case.. Stay away from the Billet ones.. Use the plastic kind and make sure its damn close to the chain.. otherwise its basicly worthless..
RIPPEN
