Case Saver?
I was really thinking about getting a case saver so I don't end up doing the great sin but didn't know if one kind was better than another. Plastic/metal? Styles?
Also, I was thinking about getting a larger front sprocket but don't know if it will fit in a case saver. Is there one that is good for both a stock and a +1 sprocket?
Thanks for the input.
Andrew
Andrew
I have a billet modquad with a13 tooth and its pretty darn close. Iknow I can go with 14 but not sure of anything bigger.
Go with a plastic type case saver if you can, they have the ability to absorb impacts much better than a metal one.
That said, here's my billet modquad with a 15 tooth.
Get the Plastic TM Designworks one. It braces its self against the cases, intead of just relying only on the 3 bolts on the bottom. It also goes behind the sprocket as well.
I have the same one and it started leaking gear case oil right after installation. It requires removal of the stock shift drum cover. Just FYI. I ahve to remove mine and see what it will take to seal it.
SP
Yep much better design I dont like how the 3 little screws are going to take a hit. I really think its an accident waiting to happen with the design I have. Cases may have better chance without it.
SP
I have a metal shift drum cover behind mine. I got it from cascade. My stock plastic one was cracked.
Yeah, a case saver is a good investment for anyone who doesn't already have one. I bought a banshee from a friend and the case had already cracked from a broken chain. Does anyone know if I can still mount a case saver on mine(just to prevent any further damage) if the case has already broke right above the sprocket?
I like the TM designworks one. It seems that that offers the most case protection of all the ones I can find.
Can someone also tell me if it is worth the extra money to run o-ring chains instead of the regular ones. I would have to burn through about three regular chains to make up the cost of an o-ring chain.
Last non oring chain I had never stopped stretching I bought right before a trip to West Virginia and the whole time I was there I was adjusting and worring about throwing my chain and breaking my case. I even had to cut a link out of it there, never go non oring again.
