TeamRealtreeHD Posted July 28, 2008 Author Report Share Posted July 28, 2008 When the bike ran better with a 2 into 1 non ported/bored motor, not to mention timing advance, dual carbs and filters, new reeds and a fresh top end 30 over, I think anybody would be pretty damm frustrated with the machine. I spent so much time trying to jet this and I put several different sizes in it, had the air screws at several locations, etc. I am getting nowhere. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 28, 2008 Report Share Posted July 28, 2008 Keihins just take time getting use to. They are more fine tunable than the stockers. Make sure you only do 1 adjustment at a time. If you do 2 you might fix 1 problem and create a new one and you wouldnt know the difference. Try 2.5 turns out on the air screw with your current jetting. If it feels a little better then drop down to a 45 pilot and reset the air scews to 1.5 turns out, and start over fine tuning the air screws. I started out on PJ's. Learning to jet PWK's is a hell of a lot easer then the older PJ's Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 28, 2008 Report Share Posted July 28, 2008 I seriously think this is a needle diameter problem. That guide says it to a T. "1/4 throttle bogging and hesitant to get on the power" means too rich of a needle/too thick of a diameter in the needle. Got it backwards. Thick needle is Leaner Thin needle is Rich 50 Pilot is to big. PWK's generally run 48-45 with CEL needles. PJ's need a little richer bottom end. 52 pilot with CEK or DEK needles. Quote Link to comment Share on other sites More sharing options...
TeamRealtreeHD Posted July 28, 2008 Author Report Share Posted July 28, 2008 Well I tried everything once again, nothing. Went out with the air screws 2 and 2.5 turns with no results. So I get in the truck and head on over to the local race shop. Bought 45 pilots and 150 mains for $26. Put the pilots in, cleared it up a littel. Tried the air screws, nothing. Did all I can do... Quote Link to comment Share on other sites More sharing options...
TeamRealtreeHD Posted July 28, 2008 Author Report Share Posted July 28, 2008 Can this problem be from reeds being bad? Quote Link to comment Share on other sites More sharing options...
xXBlessedWithDeathXx Posted July 28, 2008 Report Share Posted July 28, 2008 Lets hear them opinions on them reeds. Quote Link to comment Share on other sites More sharing options...
TeamRealtreeHD Posted July 28, 2008 Author Report Share Posted July 28, 2008 Jack, the bike is going man. I had it. I took another day to try and do this and still won't run. I think anybody that put the time into trying to get this to run as I did in the last 9 days would be just as pissed. Quote Link to comment Share on other sites More sharing options...
bigdaddy69 Posted July 29, 2008 Report Share Posted July 29, 2008 I agree with what was said in your for sale post, you should just let it sit for a couple days think about it and get back at it. I had my first ported motor last year, took me atleast a month to get it jetted correctly messing with it 4-5 times a week. On the phone with my builder 2-3 times a day if thats what I needed. Patience is key here, dont let it frustrate you & start back over from square one if you have to. Quote Link to comment Share on other sites More sharing options...
TeamRealtreeHD Posted July 29, 2008 Author Report Share Posted July 29, 2008 Thanks for the positive thinking. I am just really frustrated right now. I have the patience of a saint, I really do. I just can't understand why it's not responding to jetting. And to be honest, I put my last remaining dollar that I had to put into it. I have to pay bills as all of us do and really can't afford to buy anything if it is another problem like a stator or something. That's why I am mad. It should be just jetting, but in my case, I don't think that it is. So I am upset because I can't fix it if it is something else. Riding is over for me for sure until next year. Quote Link to comment Share on other sites More sharing options...
hercalmighty Posted July 29, 2008 Report Share Posted July 29, 2008 Just some stupid things to check. Your vent lines and gas cap, make sure they are clear and breathing. What gas are you running in that thing? What plugs and are you setting the gaps right? Just for shits and giggles try and set your timing back to +4 and see if that helps. You did say you put new reeds in right? If not spends the couple bucks for the reeds and change them out. This might not be your problem but I had the same problem with my bike and it was bad gas. Just check the bike out make sure all your wires are hooked up, all the vent lines are clear, and that you dont have some safety switch on (parking brake or tors crap). Quote Link to comment Share on other sites More sharing options...
bigdaddy69 Posted July 29, 2008 Report Share Posted July 29, 2008 he brings up a good point check your gas, Just start going over everything you can think of If you want I have a clymers manual I will send you free of charge ill pay shipping too. let me know if you want it. Quote Link to comment Share on other sites More sharing options...
TeamRealtreeHD Posted July 29, 2008 Author Report Share Posted July 29, 2008 Thanks guys, I appreciate all the help. Plugs are good, gas is fresh and mixed right. I run 116 Sunoco Maximal. I just got it the other day. I also have a clymers manual. I really appreciate the help. I just wish it can be figured out. Quote Link to comment Share on other sites More sharing options...
bbcmudtruck Posted July 29, 2008 Report Share Posted July 29, 2008 Your running straight 116? Whats your compression? Quote Link to comment Share on other sites More sharing options...
TeamRealtreeHD Posted July 29, 2008 Author Report Share Posted July 29, 2008 Straight 116. That's what was recommended. I am testing it ASAP as soon as I can get my hands on a threaded comp tester. Hopefully tomorrow. But I am currently working out some deals on some of the parts. If I can sell this bike I would rather just do that. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 29, 2008 Report Share Posted July 29, 2008 Electrical problems can have you chasing jetting all day with no results. Check the stator out with an Ohm meter. Quote Link to comment Share on other sites More sharing options...
