BlntdEyez Posted July 20, 2008 Report Share Posted July 20, 2008 I rebuilt my top end about a week ago. Everything was fine she was running great until yesterday. I was riding around my house when she just died. I was about half throttle in 3rd gear. Its got spark and fuel to the bowls. Where should I go next? Quote Link to comment Share on other sites More sharing options...
shee4speed Posted July 20, 2008 Report Share Posted July 20, 2008 Do you still have compression? Quote Link to comment Share on other sites More sharing options...
BlntdEyez Posted July 20, 2008 Author Report Share Posted July 20, 2008 Do you still have compression? I haven't ran a compression test yet. But I can kick it over and feel air coming out of the silencers. Quote Link to comment Share on other sites More sharing options...
shee4speed Posted July 20, 2008 Report Share Posted July 20, 2008 Hows the plugs look? Are they wet? Quote Link to comment Share on other sites More sharing options...
BlntdEyez Posted July 20, 2008 Author Report Share Posted July 20, 2008 Hows the plugs look? Are they wet? Plugs are a little black but not wet. I appreciate the help. Quote Link to comment Share on other sites More sharing options...
shee4speed Posted July 20, 2008 Report Share Posted July 20, 2008 Is it even trying to fire up?Is the choke tube connected between the carbs? Quote Link to comment Share on other sites More sharing options...
BlntdEyez Posted July 20, 2008 Author Report Share Posted July 20, 2008 Is it even trying to fire up?Is the choke tube connected between the carbs? The choke tube is connected. About every 7 or 8 kicks it sounds like it kinda wants to backfire? Quote Link to comment Share on other sites More sharing options...
C&B Posted July 20, 2008 Report Share Posted July 20, 2008 Put new plugs in and see what she does. Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted July 20, 2008 Report Share Posted July 20, 2008 compression test! should have done that before rippin on it Quote Link to comment Share on other sites More sharing options...
BlntdEyez Posted July 21, 2008 Author Report Share Posted July 21, 2008 compression test!should have done that before rippin on it I was trying to put some ride time in it before doing a test. I'll see wat numbers I get tommorow and post them up. Anybody else got any ideas? Quote Link to comment Share on other sites More sharing options...
ahcgt Posted July 21, 2008 Report Share Posted July 21, 2008 Have you checked to make sure you didn't shear your key for your flywheel? Mine did the same thing your talking about. Ran and then just died. Was getting fuel and spark but would backfire after a few kicks. Turned out the key sheared and it had jumped timing. Took the flywheel off and re-aligned it where it was suppose to go and started first kick. Worth taking a look at if I were you. Quote Link to comment Share on other sites More sharing options...
BlntdEyez Posted July 21, 2008 Author Report Share Posted July 21, 2008 Have you checked to make sure you didn't shear your key for your flywheel? Mine did the same thing your talking about. Ran and then just died. Was getting fuel and spark but would backfire after a few kicks. Turned out the key sheared and it had jumped timing. Took the flywheel off and re-aligned it where it was suppose to go and started first kick. Worth taking a look at if I were you. That's a very good possibility. I didn't think about that. Quote Link to comment Share on other sites More sharing options...
