Cool Head Domes
With the stock head on bend a pice of solder in the shape of an L. Put it in through the spark plug hole so it touches the cylinder wall. You want to go paralled with the wrist pin in the piston. Roll the motor over by hand. It will smash the solder and that is your squish clearance. You could aslo get a measure ment by using a dial calipar. You know the long part that comes out of the handle when you opean the calipar up.
Talk to david noss at www.nossmachine.com He makes cool heads and domes. He will be able to fix you up. BHQ members get 10% off too.
josh
Yes, if you can get a good measurement of how far the edge of the piston is above the cylinder at TDC, and know what style piston you have (Blaster or Banshee).
-David
