Banshee + dmc 916 VS ME
akheron
HI everybody,
I got a 2k1 banshee and I put a dmc 916 pipe kit on it. chek out my spec:
quebec / saguenay elevation : 1000ft
main jet : 280
pilot: 30
center clips
1 1/2 on air screw
no air box lid
gas ratio 40:1 . . . yamalube
i want to increase my torque, low range. I have a little bit of mid range & lot of hi range.
i know that it's just a jetting problem and i want some info about wich jet i should use to make it work welll
thanks
(sorrry for my pooooooooor english writtng!!!)
actually. the jetting seems right for ur elevation. but getting more low range out of a shee with dmc pipes is goin to be a trick.
i have 2 banshees with FMF'S and they are all low to mid with some high range i have 1 shee with TOOMEY T5's and its little bit of low. lots of mid and a helluva top end punch and then my last banshee is stock bore and stroke. no porting. stock carbs and perfect jetting and on that bike its NO low end what so ever. it bogs on low then hits mid starts to get it and then topend kicks in and its. gone
jetting wont get you that much more low end your probably looking for. its mostly the pipes you have chosen
BUT of course you can always change your gearing.
any bog is a bad bog , properly jetted, or close to it, VS a rich jetted banshee are worlds apart, even one clip on the needle can make a huge difference
DMC recommends ridiculous jetting to people, thats why the low end sucks so bad, everyone listens to them and puts 30 pilots in, at least this guy didnt llisten to them and put a 340 main in too, haha
well it mostly only bogs when you try a 2nd gear start.
