twinrock Posted July 15, 2008 Report Share Posted July 15, 2008 anyone used this set up? http://www.vitosperformance.com/atv_parts/...=1&featured how does it compare to cub set up? Quote Link to comment Share on other sites More sharing options...
blaat Posted July 16, 2008 Report Share Posted July 16, 2008 Im not sure if this will help you but I do have a complete vitos big bore cyl and crank kit nd am pleased. I have never ran a cub motor so I cant compare but the vitos rips!! Good customer service too!! Quote Link to comment Share on other sites More sharing options...
SQUIRREL MASTER Posted July 18, 2008 Report Share Posted July 18, 2008 if you look around the drag section someone made a thread about that set up and it went to like 4 pages. you should check that out. Quote Link to comment Share on other sites More sharing options...
Meat Posted July 19, 2008 Report Share Posted July 19, 2008 Iv had the vitos 404 kit for many years and its fun and reliable too. I wouldnt get one unless your out of cylinder wall and you need a re-sleeve. If you need a re-sleeve and don't have a fortune, or don't care about having the fastest drag bike on the planet, then the Vito's kit is an inexpensive alternative to aftermarket cylinder kits. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 19, 2008 Report Share Posted July 19, 2008 Iv had the vitos 404 kit for many years and its fun and reliable too. I wouldnt get one unless your out of cylinder wall and you need a re-sleeve. If you need a re-sleeve and don't have a fortune, or don't care about having the fastest drag bike on the planet, then the Vito's kit is an inexpensive alternative to aftermarket cylinder kits. The kit his is talking about is an aftermarket cylinder kit. They look almost like stock oem cylinders. If your looking for all out HP then the cub is the way to go. Vito's kit would probably be good for some one wanting a big bore kit with out the drag porting that a cub has. Quote Link to comment Share on other sites More sharing options...
