additional boost ports
i was told and have heard of some people adding "boost ports" or "worm holes", that are 1/4" in diameter to their intake on the cylinders, that lead directly into the transfers. i've seen some photos and am able to do this work myself, but i have also heard that it weakens the cylinder and you have to add some tig weld on the outside of the cylinder. i want to know if its really worth the hassle? so far it doesn't seem like it. i only trail ride and cruise around in the local farmers field, so i need reliability. here's a link to a pic that i was thinking about doing.
http://images.google.com/imgres?imgurl=htt...l%3Den%26sa%3DN
its on page 3 and its one of the pics on the left side. it will have the discriptions and labeling of the boost ports and size.
Edited by mopar1rules
if your building a drag bike then yes. It allows more A/F to enter the crank case . There is more to it then just drilling the whles though, the side shape and angle are all very important. I havent heard that you have to weld anything. Talk to Kevin with Herr Jugs Racing, he can give you some info on it I'm sure
maybe the tig welding talk came into play with the talk of triple exhaust ports and i just mixed 'em up?
I've seen boost ports that broke through the cylinder and were welded back up. It has been 8 or 10 years ago, and if I remember right it was a Paul Turner port job.
SP
Edited by spurdy
I haven't had much luck seeing any real gain with them in my portwork. I know passion uses them, there are some good pictures of them on his website (that's what his 12port is). 1/4 inch holes wouldn't require any tig welding, but I'm sure to see a gain you would have to go bigger and also cut an additional port window into your rear transfer port. They claim it helps low speed atomization and high speed flow. I'm going to play with them more extensively on my next personal engine. You can find a link to passions website in the dealers area of Noss machine.
  • 3 months later...
slobanshee, did you ever get the chance to play w/the boost ports on your personal engine yet?
I found that they did offer a minor low to mid power increase at the expense of some top end power with my portwork. I didn't however cut the added windows in the sleeve. I ended up filling them in and haven't messed with them since. I have found a lot more power playing with transfer durations and angles as well as experimenting with exhaust port shapes. Honestly to see any real gain with the boost ports on a stock cylinder setup I think you will have to have them welded so you can go larger and add the windows. My best advice is to try it for yourself and see if it works for you. What works with one builders portwork doesn't necissarily work with anothers.
Glad you followed up, Mine are not large at all and are set up for drag. Although my friends K&T has added material and they are similar to the ones dave posted, and they haul some ass..... How large were the ports on yours Slo?
