:confused: ok i'am noob to banshees and twostrokes ok here is my ? do you have to mix the gas and oil together and then put it in the bike because i have a bud with a twostroke yamaha dirtbike that says you dont and a bud with a twostroke atv that says you have to so do you have to mix oil and the gas or can you pull up to the pump and put stright gas in it
Yes. you need to mix the gas. Steal your moms measuring cup out of the kitchen. Then put 4 ounces of 2 cycle oil per gallon of gas. If you dont do that SHEE will die a premature death.
Your bud with the bike probably has oil injection, like on a Blaster.
Edited by pabansheematt
I put the gas in underneath the kickstarter where the dipstick is and the oil in that big tank in front of the seat. :evil:
16 ounces of Maxima Castor 927 2-Stroke Oil in a 5 gallon can first, then put 5 gallons of gas on top of that which will mix it for you. Then pour into shee. Thats a 40:1 mix, you might want to go 32:1 though which would be a little less gas.
See oil here...
http://www.rockymountainatv.com/productDet...odFamilyId=3222
All 2 strokes need oil in the gas to lubricate the engine period.
Some bike are oil injected,which means it has a seperat tank that you fill with oil,and it injects
oil into the engine,just like my sons 90cc predator.
Banshees don't have oil injection,so you'll need to mix your oil with the gas.
Sounds like your dirtbike buddy is trying to sabotage you! You definitely don't want to run straight gas in a Banshee. I use the Yamalube 2R oil, and mix a little rich at 24/1 ratio. 16 0z's to 3 gallons premium gas.
Yeah your buds bike must be oil injected with a seperate resevoire if he doesn't pre-mix.....
