TIMING PLATE SET AT -5
T-daddy
i was thinking about getting a rap 700 but i love my shee the power is crazy
so im just gonna due up the shee instead of spending 8k on the raptor
i see your tryin to get rid of your z and the 700 so i guess u like the fell of the banshee over the 4 stroke
I was going to get rid of them to get a drag banshee but now Im prolly keeping them.This banshee will prolly never see a trail in its life lol I have two good trail bikes.If ALL you do is trail ride and mud ride I would get a raptor.Stock on stock and piped vs piped and bolt on vs bolt on the raptor 700r is faster.
I'm not sure why you would even retard the timing...
Power adders, ie: nitrous. The only reason I could think of running retarded timing. More than likely the previous owner didn't know what the - and + meant...lol
As for the problems with the pull in the higher gears, yes it could easily have been the cause. Would have killed what little low end your shee might have had.
could it also make it a little harder to start the bike with the timing being retarded
ok i started the bike up today it sounded funny after going +4
it reved faster it was like really high idle so i lowered the idle then it sounded normal but when i reved it i noticed when it calms down to idle i hear a rattle coming from the topend not loud but i noticed is it detonating or is that a sound it gets when u advance the timing
Put the plate to 0.
At 120 PSI (if that's an accurate reading from an accurate gauge) with pump gas it shouldn't detonate.
But, if you put a few steel ball bearings in the motor when it's running, that's what detonation sounds like...not good.
Do you know what size jets are in the carbs??
Put the plate to 0.
oh ok it doesnt sound like that
but i put it at zero and i can still here it but i guess its nothing
it may be something else rattiling but i no medal is slappin medal somewere i just have to find it
but i have 280 mains in and 25 pilots for fmf pipes and no lid on airbox
should i go up on the main and pilot for those mods
do i have to rejet when i add timing
Leave it alone for now and go ride it! Then report back...
lol i made sure it wasnt that
figured out the rattle
me being in a rush to ride i didnt put the left pipe on tight because i was cleaning them
but the pipe was hitting the head and rattiling
i fixed it and rode it with the timing at 0 but im gonna try +4 2morrow
but at 0 it was a big difference it gets up :woot:
i was missing out on the true power for 2 years now :down:
