ThE_BaNsHeE_mAn88 Posted July 13, 2008 Report Share Posted July 13, 2008 ok i bough two teathers and both dont work i dont know if the curcits are different then what the banshee's are, or im hooking them up wrong, idk! od you splice them where the key is or do you splice them into the coil, any help will be really great. thanks! Derick Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted July 13, 2008 Report Share Posted July 13, 2008 you should be able to splie them at the switch. You have to ake sure you hve the ground on the correct side. the tether runs the circut open while its in, and when you pull the tether it should ground the circut making the motor die. Quote Link to comment Share on other sites More sharing options...
ThE_BaNsHeE_mAn88 Posted July 13, 2008 Author Report Share Posted July 13, 2008 (edited) ya i had it wired into the key switch and when you had the clip in the bike wouldnt run but when you pulled it out it would so it worked backwards. hey and that saying you have is from an everytime time i die song right? Edited July 13, 2008 by ThE_BaNsHeE_mAn88 Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted July 13, 2008 Report Share Posted July 13, 2008 you probly just have it wired backwards. and yes it is Quote Link to comment Share on other sites More sharing options...
rubberneck Posted July 14, 2008 Report Share Posted July 14, 2008 ya i had it wired into the key switch and when you had the clip in the bike wouldnt run but when you pulled it out it would so it worked backwards. hey and that saying you have is from an everytime time i die song right? You dont want to wire it to the key switch, you need to go into the run/kill switch harness and tie one of your tether wires to the black/white wire and the other wire from your tether either gets run to ground or tie it into a black ground wire in the same harness. Do not run it to the coil, this can be hard on the CDI. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted July 14, 2008 Report Share Posted July 14, 2008 You dont want to wire it to the key switch, you need to go into the run/kill switch harness and tie one of your tether wires to the black/white wire and the other wire from your tether either gets run to ground or tie it into a black ground wire in the same harness. Do not run it to the coil, this can be hard on the CDI. rubber i think thats what he did. He took the wires from the switch and wired it in... are you talking about the wires from the key? Quote Link to comment Share on other sites More sharing options...
