raptor is like a cheap hooker with every disease known to man.an ugly banshee is a high class whore that spends the night and washes your car.
Very nice amigo! LOL!
My Banshee's been running like $hit since the rebuild, but then I remembered reading something about the slides being switched. I checked the slides and Wtf, I had them on backwards...Can't wait till it's daylight to test it. :evil:
Lol!! Part of the fun of owning a Shee... :biggrin: Bike looks good--especially when compared to the "before" pic.
So I decide to check my Spark Plugs and this is what they look like... :ermm:
The one on the Left came off the left cylinder (choke side). The one on the right came off the right cylinder. I'm wondering WTF is going on??? :huh:
Check the obvious stuff, a good carb cleaning might be in order if you haven't already done that. Make sure you don't have a clogged main jet in one of your carbs, that is what happened to me a month after I bought my Banshee. This is what happened to the motor: Motor Woes
Also check to make sure you are getting spark on both sides of the motor. Did you do a leakdown test when you put everything back together?
  • 1 month later...
An ugly Banshee is still better than a "pretty" Craptor...
Lol didn't someone make a song about the craptor? somthing like..
craptor craptor
it's the quad theat cheats to go faster
craptor craptor
Okay, back to the subject...
I had a feeling that my crank seal was bad...
My stator is probably weak also...
I pulled off the head and was disgusted...This is the second brand new piston set and head that got F@CKED up with less than 2 hours run time...
So I decide to just go all the way and Split the Cases.
More Problems...
Shavings and old piston pieces...
Crank Bearing and Seal Wasted...
I originally Purchased the Bike for $500 and have since put about $2000+ in parts and lots of my time. It's like being in a bad Marriage.
Overall, working on the motor was easier than Sunday Morning.
Gotta wait for more parts to get in to finish... :confused:
