T-daddy Posted July 12, 2008 Report Share Posted July 12, 2008 wen i was riding my bike earlier i noticed it smokes alot after its warmed up i run 32:1 premix yamalube 2r .witch i hate it smells bad i wanted to know if i run 40:1 would it stop smoking as much and is there a better premix to use that smells better and if it matter my jetting is 280m 25p mods fmf gold series prodesign filter airbox no lid Quote Link to comment Share on other sites More sharing options...
T-daddy Posted July 13, 2008 Author Report Share Posted July 13, 2008 another question i just noticed i had a timingplate its set at -5 could that explain the crappy running and what should i set it at Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 13, 2008 Report Share Posted July 13, 2008 Yea the plate at -5 might not be the best. What kind of fuel and compression are you running. Most people run +4 on premium fuel at 150 PSI compression. If your running Race fuel at 180 PSI compression then most people run +6-+8. As for the oil Klotz Supertechniplate is a great oil and it smells good. I would try Klotz Supertechniplate at 32:1 first. That way you wont have to mess with the carburetors. If you lean out the oil you increase the fuel so you might have to change the jetting. josh Quote Link to comment Share on other sites More sharing options...
T-daddy Posted July 13, 2008 Author Report Share Posted July 13, 2008 (edited) Yea the plate at -5 might not be the best. What kind of fuel and compression are you running. Most people run +4 on premium fuel at 150 PSI compression. If your running Race fuel at 180 PSI compression then most people run +6-+8. As for the oil Klotz Supertechniplate is a great oil and it smells good. I would try Klotz Supertechniplate at 32:1 first. That way you wont have to mess with the carburetors. If you lean out the oil you increase the fuel so you might have to change the jetting. josh my compression is 120 in both cylinders what would running it at -5 do would it make it harder to start i use 93 from the pump Edited July 13, 2008 by T-daddy Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 13, 2008 Report Share Posted July 13, 2008 yea it might make it harder to start. Since your running a stock head and premium set the plate at 6 deg. Increasing the timing helps boost midrange. Quote Link to comment Share on other sites More sharing options...
T-daddy Posted July 13, 2008 Author Report Share Posted July 13, 2008 yea it might make it harder to start. Since your running a stock head and premium set the plate at 6 deg. Increasing the timing helps boost midrange. ok ill adjust it 2morrow and see what happens and were can i get some Klotz Supertechniplate Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 13, 2008 Report Share Posted July 13, 2008 You can get it from RM ATV http://www.rockymountainatv.com/typeDetail...amp;webCatId=23 Quote Link to comment Share on other sites More sharing options...
Paddleboy Posted July 13, 2008 Report Share Posted July 13, 2008 most dealerships should carry it on hand. i use klotz r50 and i love the smell Quote Link to comment Share on other sites More sharing options...
rusty1100 Posted July 13, 2008 Report Share Posted July 13, 2008 As for the oil Klotz Supertechniplate is a great oil and it smells good. MMMMMMM Klotz Supertechniplate, it just smells soooo gooood. I wish everthing I owned ran off of that stuff. Quote Link to comment Share on other sites More sharing options...
mopar1rules Posted July 15, 2008 Report Share Posted July 15, 2008 klotz smells good, but i sure love the smell of my amsoil dominator. i run 50:1 and no smoke. nice and clean w/good smell. Quote Link to comment Share on other sites More sharing options...
