TeamRealtreeHD Posted July 12, 2008 Report Share Posted July 12, 2008 I think I will invest into one... what do you guys think? Do they cool better? Is there any other work that needs to be done with the cooling system, or anything else in general, other than just bolting them on? I was looking into a BOSS Quote Link to comment Share on other sites More sharing options...
KaosBanshee44 Posted July 12, 2008 Report Share Posted July 12, 2008 What kind of mods do you have? Quote Link to comment Share on other sites More sharing options...
TeamRealtreeHD Posted July 12, 2008 Author Report Share Posted July 12, 2008 -HJR hot hillshooter port -bore and hone .020 by HJR -Wiseco .020 pistons and top end kit -Noss Head with 17 cc domes - +6 timing -pwk 33's -boss intake with crossover -trinity stage 4 exhaust and silencers -k&n pod filters -barnett clutch springs Quote Link to comment Share on other sites More sharing options...
KaosBanshee44 Posted July 12, 2008 Report Share Posted July 12, 2008 Yeah it'll help out i personally like em' better than the stock radiators but that's only if your sticking with gas if you run alky or want to in the future i wouldn't get it since alky will help run cooler anyway. That's why i didn't get one all i did was clean mine out real good strip the paint and will use my stock one since i'm gonna run alky. I also didn't like the price tag on them either i think there way over priced. You won't believe how much crap gets in between the fins on the radiator too if you gonna stick with it i'd take it off and clean it up real good it will help a little bit. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 12, 2008 Report Share Posted July 12, 2008 I have a Pro designe on mine. It helped out a bunch. I do some trail riding and playing around at a hill climb when I go riding. I dont really even have to worry about it overheating now. I would run engine Ice too. If you get a larger radiator you will need 2 jugs. dajo was selling 3 boss radiators on ebay. 299 with free shipping. My PD was 375 shipped so it is a pretty good deal. josh Quote Link to comment Share on other sites More sharing options...
TeamRealtreeHD Posted July 12, 2008 Author Report Share Posted July 12, 2008 I will definately run the ice... but I am going to get one, just don't know how soon. I think they are overpriced by a few bones Quote Link to comment Share on other sites More sharing options...
pabansheematt Posted July 12, 2008 Report Share Posted July 12, 2008 I think I will invest into one... what do you guys think? Do they cool better? Is there any other work that needs to be done with the cooling system, or anything else in general, other than just bolting them on? I was looking into a BOSS Dont waste your money, they do nothing, Water wetter also does nothing. Billit impeller helps a little. Best way to keep it cool is ride it really f-in fast!! Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 12, 2008 Report Share Posted July 12, 2008 So increasing the surface area of the radiator and increasing capacity of the cooling system does nothing? My banshee ran ran 190 tearing down gravel roads. Now that I have my pd radiator it runs 160. It runs 180 trail riding off the pipe at slow speeds. josh Quote Link to comment Share on other sites More sharing options...
pabansheematt Posted July 12, 2008 Report Share Posted July 12, 2008 So increasing the surface area of the radiator and increasing capacity of the cooling system does nothing? My banshee ran ran 190 tearing down gravel roads. Now that I have my pd radiator it runs 160. It runs 180 trail riding off the pipe at slow speeds. josh i'm tellin ya. I made zero difference with my bike. I got the Torch Works rad in mine. It's a little bigger, it nicer, but I saw no difference in Running temp. I have two temp gauges, one on each line so I know my gauges are correct. I've talked to other people on here who said the same thing. I should have listened. Quote Link to comment Share on other sites More sharing options...
Ducman Posted July 12, 2008 Report Share Posted July 12, 2008 I have the toomey radiator with my 421 cub motor. It does make a difference but it only keeps it from overheating for a hair longer than with the stock radiator. If I were you I'd do the billet impeller and engine ice first, that will also make a noticeable difference for under $100 compared to $300+ for a radiator. Quote Link to comment Share on other sites More sharing options...
2strokespirit Posted July 12, 2008 Report Share Posted July 12, 2008 I am with JB, bigger cooling service, helps out a lot on the slower trails, never overheats with the pro design. There is a lot of guys that say if your bike overheats with a stocker, you have other issues or jetting issues, nonsense, you can be jetted spot on, but on the slower trails it will overheat on a very hot day and its there where the oversize rad comes in very handy.. I do some fast cross country in SA and on a hot day in the desert, 50 degrees C it will run very hot (not overheat) on wide open throttle, and the jetting is spot on. With the oversize it just runs cooler for sure... Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 12, 2008 Report Share Posted July 12, 2008 It made my banshee run cooler. Maybe all aftermarket radiators arent equal. I got the PD one because it was the biggest looking one. Has big end tanks and and barly fits under the radiator cover. It takes 1 and 1/4 jugs of engine ice to fill up, where the stock one can be fill with just a little over 3/4 of a jug. And it is bare aluminum instead of painted aluminum. Quote Link to comment Share on other sites More sharing options...
dlnoss Posted July 14, 2008 Report Share Posted July 14, 2008 Like some of the others suggested, I would do the billet impellar and engine ice first. -David Quote Link to comment Share on other sites More sharing options...
