doug Posted July 18, 2008 Author Report Share Posted July 18, 2008 Hi There, Thanks again for the wiring photos. I'm getting things back in order. It's strange what some guys do to Banshees. I was hoping you might be able to help with with a couple items that I couldn't figure out from the photos? 1) Does the throttle cable run up the kick-start side of the bike? 2) Is the throttle cable supposed to be ti-strapped together with the other wires, etc. that run underneath the gas tank and through the square bracket attached to the frame? 3) Do all wires run overtop of the fuel lines (going to each carb) and the little rubber carb sync tube (used for choke if I'm not mistaken) (I'm going to ditch the tors soon....I really fought with a previous set of carbs though, I haven't yet figured out what it was - they had the TORS removed. So the plan is to get the bike back to stock, running well and then go from there) BTW - I had an amazing ride this past weekend. Here are some photos... http://picasaweb.google.com/dougstackhouse...key=4S4_GeAmUhE Thanks for the help. bump Quote Link to comment Share on other sites More sharing options...
05.Banshee.SE Posted July 19, 2008 Report Share Posted July 19, 2008 Damn, that looks like a fun ride, and a nice scenic place. I'm in the process of moving right now, but I'll try to get you the info ASAP. Quote Link to comment Share on other sites More sharing options...
