plug chops
i know that the best way to check your plugs is to chop them, but i have never done it. so do i cut the plug in half at the base of the treads or do you cut all the way around the threads so as not to cut the ceramic inside? thanks for any info
When you cut the thread look for the ring around the base of the electroid.2mm chocolate-brown ring is spot on.Taller then 2mm or darker brown your rich.If the ring is smaller the 2mm or lighter,or nonexistent your lean on the mains.
