Bill Posted July 3, 2008 Report Share Posted July 3, 2008 Ok I got A newer style key switch(square plug)and my shee has A 89 harness, so I need to hard wire it. Now I know that I need to complete the circuit in order for it to run. There is four wires coming of the switch, the blk and the blk/wht wires show continuity and same with the red and brown.My question is does it matter what two wires I use to complete the circuit? If I use only two wires do I just tape off the other two separately? Thanks for any info, Bill Quote Link to comment Share on other sites More sharing options...
spurdy Posted July 4, 2008 Report Share Posted July 4, 2008 Ok I got A newer style key switch(square plug)and my shee has A 89 harness, so I need to hard wire it.Now I know that I need to complete the circuit in order for it to run. There is four wires coming of the switch, the blk and the blk/wht wires show continuity and same with the red and brown.My question is does it matter what two wires I use to complete the circuit? If I use only two wires do I just tape off the other two separately? Thanks for any info, Bill Should be that the black and the black w/white go together. The other 2 are not used. SP Quote Link to comment Share on other sites More sharing options...
