Stock Compression?
Hi, I guess I'm new to a stock Banshee. I've built a couple with close to 200 psi compression, but I can't find what the minimum compression values should be for a stock shee. I did a search here but I got into way more stuff than expected. I'm running about 120psi on each cyl. If elevation is an issue I'm about 2000ft above sea lev.
