seabass Posted June 29, 2008 Report Share Posted June 29, 2008 I've seen this covered before but the search turned up nothing. I put different reeds on the cages. The screws and lock washers have only been removed once since I replaced them. Should I add a dab of Lock Tite or tighten it down without it? I'd rather not use it if I don't have to. All opinions are appreciated. Thanks alot guys. Quote Link to comment Share on other sites More sharing options...
87bansheeguy Posted June 29, 2008 Report Share Posted June 29, 2008 no need for it really they will be fine without locktight just tighten them down good without stripping them Quote Link to comment Share on other sites More sharing options...
bansheejoel Posted June 30, 2008 Report Share Posted June 30, 2008 no need for it really they will be fine without locktight just tighten them down good without stripping them i disagree, I would put locktight blue on them. If you need to you can get them out easily. If you loose a screw in your cylinder your fucked. Be on the safe side and use a tiny bit. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted June 30, 2008 Report Share Posted June 30, 2008 i disagree, I would put locktight blue on them. If you need to you can get them out easily. If you loose a screw in your cylinder your fucked. Be on the safe side and use a tiny bit. Agree Quote Link to comment Share on other sites More sharing options...
spurdy Posted June 30, 2008 Report Share Posted June 30, 2008 i disagree, I would put locktight blue on them. If you need to you can get them out easily. If you loose a screw in your cylinder your fucked. Be on the safe side and use a tiny bit. I disagree as well. A little locktight is nothing more then a little insurance. Anything to insure no foreign shit in my cylinders! SP Quote Link to comment Share on other sites More sharing options...
