YamahaMama Posted June 26, 2008 Report Share Posted June 26, 2008 (edited) Hey guys, well I just found out Jeff left for a little while for a vacation. I have been trying to get a hold of him to find out what he recommends for jetting for my new setup. Since he is out relaxing (more power to him) I was looking to get some insight from the veterans on some recommendations. We got her running and everything is good. We have just been breaking it in, heat cycyles, no high RPM stuff yet. It seems to run really good down low and also mid but my husband is concerned about the top end. If you can give me a good starting point for the jetting I would appreciate it. Here is a list of what I have got from you in it. 65mm Wiseco Pistons 4mil Crank Mild Porting on the cylinders and the transfers on the top of the case 21cc Domes with a FAST head 35mm PWK's V Force 3's I am pretty much at sea level over here We are leaving tomorrow morning and want to adjust the jetting when we get down there. Let me know guys! Edited June 26, 2008 by YamahaMama Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted June 26, 2008 Report Share Posted June 26, 2008 150-155 mains, 45-48 pilot, CEL middle clip, 2.5 turns on air screw. will get you right around whta you need Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted June 26, 2008 Report Share Posted June 26, 2008 150-155 mains, 45-48 pilot, CEL middle clip, 2.5 turns on air screw. will get you right around whta you need Yep Might grab a pair of 158's just in case. Quote Link to comment Share on other sites More sharing options...
YamahaMama Posted June 26, 2008 Author Report Share Posted June 26, 2008 Ya we just bought a shit load of jets so Im sure we have some of those around here... Thanks for the advice guys! Keep it coming! Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 27, 2008 Report Share Posted June 27, 2008 id say 45 on the pilot and 155 to 160 on the main. i dont think you can go wrong in there.. 2.5 turns on air screw and needle in the middle. that should get you going. Quote Link to comment Share on other sites More sharing options...
moneybags Posted June 27, 2008 Report Share Posted June 27, 2008 (edited) My 4mill dune and play port Banshee built by Jeff. Is use 165 mains and 48 pilots. I should drop down a size on the main jet (summer time) It has all the good stuff. 35PWK's noss head 20cc domes 185psi at sea level V-force reeds pod filters Shearer pipes +5 timing .020 over Edited June 27, 2008 by moneybags Quote Link to comment Share on other sites More sharing options...
YamahaMama Posted June 27, 2008 Author Report Share Posted June 27, 2008 My 4mill dune and play port Banshee built by Jeff. Is use 165 mains and 48 pilots. I should drop down a size on the main jet (summer time) It has all the good stuff. 35PWK's noss head 20cc domes V-force reeds pod filters Shearer pipes What elevation are you at? Quote Link to comment Share on other sites More sharing options...
Hilarious Posted June 27, 2008 Report Share Posted June 27, 2008 My 4mill dune and play port Banshee built by Jeff. Is use 165 mains and 48 pilots. I should drop down a size on the main jet (summer time) It has all the good stuff. 35PWK's noss head 20cc domes 185psi at sea level V-force reeds pod filters Shearer pipes +5 timing .020 over that was my setup, spot on. mine was perfect with a 160 main, CEL needles with clip on 2nd groove from the blunt end. Quote Link to comment Share on other sites More sharing options...
YamahaMama Posted June 27, 2008 Author Report Share Posted June 27, 2008 Thanks again guys! We are on our way to the dunes I will let you know if ran when I get back Monday! Quote Link to comment Share on other sites More sharing options...
YamahaMama Posted June 30, 2008 Author Report Share Posted June 30, 2008 Well thanks again for all the advice guys... We actually forgot what jetting was in the bike from the first small build we had on the motor and there was 168 mains actually in the bike so we tried some 175 mains and it was alittle rich so we dropped it down to 172 main jets, needle in the middle, 45 pilot and 2 1/2 turns out on the fuel screw and she runs great! :biggrin: Quote Link to comment Share on other sites More sharing options...
